Spindle Sander
Forum topic by lalkie posted 12-30-2018 10:17 PM 1017 views 0 times favorited 8 replies Add to Favorites Watch
View lalkie's profile
lalkie
28 posts in 1757 days
12-30-2018 10:17 PM
I am looking at purchasing a spindle sander. Most of them have about a 4.5 inch sleeve but only a 1.5 inch stroke. Are the any spindle sanders with a longer stroke? Thanks Larry
8 replies so far
View WoodenDreams's profile
WoodenDreams
1071 posts in 688 days
#1 posted 12-31-2018 02:14 AM
If your concerned about using up the whole sanding sleeve. All you have to do is flip the sanding sleeve over to use the other portion of the sleeve, when one end of the grit is worn down.
View mpsprunger's profile
mpsprunger
34 posts in 2638 days
#2 posted 12-31-2018 02:01 PM
State oscillating spindle sander is, as far as I’m concerned is the best, it’s stroke is 1 5/8, its very smooth running and heavy
View xeddog's profile (online now)
xeddog
304 posts in 3784 days
#3 posted 12-31-2018 06:05 PM
Besides, if you had a 4.5” sleeve and your spindle sander had 4.5” travel, you would just be bending the spindle at the top end. Obviously more so for the smaller spindles.
Wayne
View pottz's profile
pottz
9907 posts in 1761 days
#4 posted 01-01-2019 12:09 AM
as far as trying to use the whole sleeve I just made a top out of 2 pieces of melamine that i put on the table which raises the the surface another 1-1/2” to utilize the whole sleeve.i did the same on my edge sander.
View Turns4wood's profile
Turns4wood
52 posts in 559 days
#5 posted 01-02-2019 04:02 AM
What might be more important than the up down of the unit is what it has for dust control. Most for some godforsaken reason have a port that matches absolutely nothing
Jerry
-- Nothing better than sawdust on the floor
WoodenDreams
#6 posted 01-02-2019 06:37 PM
The melamine jig the pottz suggested would save time. Especially on a edge sander, where you need to square the table surface again after raising it.
lalkie
#7 posted 11-20-2019 07:24 PM
Thanks for the responses. Thanks Pottz. I will probably use your idea.
pottz
#8 posted 11-20-2019 07:46 PM
- lalkie
welcome,it’s an easy fix i use on my spindle and edge sander to get the max use.
