Hal Taylor rocker
Forum topic by Jonwilliam posted 12-30-2018 04:59 AM 768 views 0 times favorited 3 replies Add to Favorites Watch
View Jonwilliam's profile
Jonwilliam
43 posts in 3906 days
12-30-2018 04:59 AM
Topic tags/keywords: question milling maloof hal taylor rocking chair rocker
To anybody that has done a Maloof style rocker, what minimum thickness stock can you use? I have 8/4 stock that measures 1-15/16” at its thickest down to 1-7/8” at its thinnest. It does need some milling to get rid of some of the sawmill marks. I figured all done it will be down to 1-3/4”.
I have Hal Taylors plans and nowhere does it mention this other than the thickness of the boards is variable. I think it will work but I don’t want to get elbow deep with that expensive wood and find out its not going to work so well.
Any experience or insight? Thanks for any help!
-- -semper fi
3 replies so far
View DrDirt's profile
DrDirt
4615 posts in 5033 days
#1 posted 12-30-2018 05:47 AM
I would e-mail Hal directly.
I have those plans as well, and am making different version of Maloof chair, but I think the thickness you describe would not be an issue. one way to get a deeper seat curve with those boards, might be to Cooper the seat boards which is how the Maloof chair is (rather than a flat board.)
Key for thickness is the seat. Keep in mind that you are going to grind a large part of it away, so don’t get too focused on making a perfect smooth seat blank, just to turn around and sculpt away the seat. You only really need it to be flat and smooth around the perimeter
Jonwilliam
#2 posted 01-14-2019 11:43 PM
Thanks I am just going to give it the ol college try. Ill post some more stuff on my build to help others
-- -semper fi
View pottz's profile (online now)
pottz
21409 posts in 2275 days
#3 posted 01-15-2019 12:29 AM
i used charles brocks plans and he has two versions one for full 2” thick material and one for 1-3/4” i built mine using the 2”. as the good dr said dont worry too much about perfectly planed boards,your gonna grind away a whole lot of it.
