Cutting acrylic
Forum topic by zipmac22 posted 12-27-2018 01:00 AM 883 views 0 times favorited 12 replies Add to Favorites Watch
View zipmac22's profile
zipmac22
44 posts in 1934 days
12-27-2018 01:00 AM
I have a piece of acrylic, 0.093 thickness) and was planning to use the acrylic sheet for a template. Has anyone cut a sheet of acrylic on their table saw? I have a Freud 10”, 50 Tooth, Thin Kerf blade on my table saw right now. What are the pros and cons of using a table saw over scoring the acrylic and snapping it?
Also, on a similar note…I need to make some round holes in the acrylic as well. Has anyone used a hole saw blade cutting through acrylic? If not a hole saw blade what would work better?
-- Chris, Central Texas
12 replies so far
View squazo's profile
squazo
209 posts in 2726 days
#1 posted 12-27-2018 01:14 AM
I have done this before and there is one thing I can tell you. The biggest thing is that it wants to pick up the back as it passes the back of the blade, you have to use a feather board or something to hold the back down.
You will need a finer tooth blade. This is a another one of those situations where using the blade on the saw backwards could help as well, it works great for PVC.
For something that thin I believe scoring and snapping is the preferred method, at least that is what I gather from all the sign making panel cutting boards I have come across while researching vertical panel saws.
A hole saw will work perfectly, as weill any other drill bits.
View bilyo's profile
bilyo
1366 posts in 2184 days
#2 posted 12-27-2018 02:12 AM
I have used a thin kerf 40 tooth combo blade on the table saw to cut 1/4” acrylic. Worked with no problems except it does not leave the smoothest of edges. I have also used both hole saw and forstner bits with no problems as well as all sizes of drill bits. Don’t force your cuts, but also don’t go so slow that the acrylic heats up. The melted plastic will gum up the blade and be very difficult to remove.
6986 posts in 3575 days
#3 posted 12-27-2018 06:00 PM
We have a large plastics supplier nearby, and they cut sheets of all kinds of plastic (including acrylic) with a negative hook blade, the backwards would be much the same thing. I’ve cut acrylic with positive hook blades, and it seems to chip at the edges (rather badly) when I do it. Cutting plastic really leaves a mess, the chips cling to everything.
View Joe Andrews's profile
Joe Andrews
85 posts in 3080 days
#4 posted 12-27-2018 06:15 PM
I cut 1/4” cast acrylic with a Irwin Marples 50 tooth blade all the time. No chipping or anything. Like others mentioned, the edge isn’t shiny smooth, but it works fine. Not sure how the thinner stock would work. But a simple test cut is all you need to do to find out.
View xeddog's profile
xeddog
341 posts in 4089 days
#5 posted 12-27-2018 06:20 PM
Three things I have found to be important in my limited acrylic cutting are blade geometry, blade height, and blade sharpness. I have had best result with a sharp TCG tooth grind, and blade height as low as possible and still cut through. But to be honest, I have not cut any acrylic as thin as 3/32”, but close at 1/8”. Lastly, I don’t know if this would work, but try taping the cut line. It helps me a lot with things like plywood, maybe it might help here too. If nothing else, it might prevent some scratching.
Wayne
View WoodenDreams's profile
WoodenDreams
1300 posts in 992 days
#6 posted 12-27-2018 08:28 PM
I have used a wood burning knife to heat cut the acrylic sheets for picture frames. A slower process verses the table saw.
bilyo
#7 posted 12-27-2018 11:26 PM
Sorry. When I made my comment above, I didn’t read your post carefully enough to understand that you are dealing with rather thin material. For thin products like that, including plastic laminate, I have had good results with special scoring knives like this one. It has a short edge, but you don’t actually cut with it. You use the back of the edge to plow a groove into the material using a pull stroke. You can either plow the groove deep enough to make a clean snap or keep plowing with multiple strokes to go clear through
View jamsomito's profile
jamsomito
657 posts in 1507 days
#8 posted 12-28-2018 12:38 AM
I just cut a 0.093” sheet of acrylic on my table saw with a 10” Freud thin kerf general purpose blade. Not the first time either. I have absolutely no issues. Only problem I ran into is if you cut too slow (like really slow) it will melt instead of cut. But it cuts better than wood for me…
WoodenDreams
#9 posted 12-28-2018 09:28 PM
For hole cuts, you could use a leather hole punch or even a cheap round center punch , heat up the end and melt in a hole.
View unclearthur's profile
unclearthur
383 posts in 2869 days
#10 posted 12-29-2018 08:23 AM
I’ve cut acrylic sheet of about that thickness with a router, 1/4” straight bit, going slow.
View ohtimberwolf's profile
ohtimberwolf
1082 posts in 3433 days
#11 posted 12-29-2018 03:01 PM
Here is some good help. larry
https://www.wikihow.com/Cut-Acrylic-Sheets
-- Just a barn cat, now gone to cat heaven.
View PropmakerLA's profile
PropmakerLA
15 posts in 1091 days
#12 posted 12-29-2018 07:38 PM
For thin Acrylic a track saw would be my first choice as the splinter guard would hold down the material to minimize any chatter. With a track saw there is also little chance of scratching the material
On a table saw we use blades specifically for plastics. With thin material set up feather board to keep material from bouncing to reduce risk of cracking, or use two people to feed material.
A router would be my 3rd choice clamping it to a table edge to use as a straight edge. Spiral trim bits work best on acrylic
