Dust Collection: If squished 4" wire hose to 1" oval, venturi effect?
Forum topic by Holbs posted 12-20-2018 04:27 AM 452 views 0 times favorited 4 replies Add to Favorites Watch
View Holbs's profile
Holbs
2258 posts in 2632 days
12-20-2018 04:27 AM
I am working on my bandsaw dust collection. Will have a 6” duct feed to it branched off to 4” wye so will have 2×4” ports. One will be installed to the lower wheel area. What to do with the other 4”. After some vids and topic discussions, I wanted to try something. I currently have a damaged 4” spiral wrapped plastic dust collection hose that was walked on or something. It’s now oval. I placed this damage piece (about…eh…12” long) under the bandsaw table with the 1” gap clearance down there. I have yet to fully connect to my 3HP dust collector.
I was thinking of the ‘ol carburetors and the venturi affect of pulling air through a smaller opening increasing the speed. Will this apply to this dust collection setup for the bandsaw blade?
A 4” hole will have a 12.5” square inch area. With this damaged hose, the opening hole is more like 5-6” square inch area.
View SuperCubber's profile
SuperCubber
1088 posts in 2888 days
#1 posted 12-20-2018 12:04 PM
That seems like a logical line of thinking, but as the air exits the Venturi, it will slow back down. I don’t see a big benefit.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View EarlS's profile
EarlS
3413 posts in 2951 days
#2 posted 12-20-2018 12:58 PM
Yes, the velocity will increase through the venturi, but it will result in a lower airflow at the mouth of the pipe where you want the highest air flow to pull the dust and chips into the hose. You would be better off to leave the 4” line the same size and not reduce it and make wide mouth inlet for the bottom of the bandsaw.
BTW – there was some discussion on the Spring Swap forum between Dave Polaschek and a couple other LJ’s about making DC adapters to use under the bandsaw table. I’ll post a note there to have him chime in here.
View MikeDilday's profile
MikeDilday
284 posts in 1062 days
#3 posted 12-20-2018 01:02 PM
If using a 6 to 4” wye gives you an extra 4” why didn’t you just use a 6-4 reducer and only have one 4” pipe?
-- Michael Dilday, Suffolk, Va.
Holbs
#4 posted 12-21-2018 02:25 AM
The measurements underneath the bandsaw table (clone bandsaw) is roughly 1 ” of space. That is my limiting factor. The venturi center point would actually be where the bandsaw blade is. But Earl says slow air flow from the get go due to the venturi anyways. Hmm…
Well…I’ll try it out anyways :) I just bought that router dust collector vinyl boot thingy (Milescraft Dust Router). Wonder if a 2nd one would work on a bandsaw.
Will be a busy weekend for installing and testing!
If all else fails, new DIY bandsaw table with dust collection chambers here I come! Even if it means losing 2-3” of resaw height (as if there is much to begin with on this 14”).
