Forum topic by derhul | posted 12-19-2018 10:07 PM | 1792 views | 0 times favorited | 7 replies | ![]() |
Topic tags/keywords: steel hand plane making hand plane sole tool making plane tip resource question hand tools sole steel hand plane steel Hello, I would like to get into making hand planes with steel sides and soles (much like Youtuber Young Je). I’ve hand made a few knives with 1095 stainless steel(and have a lot of stock left over). Can I use this steel for the sides and soles? If not, what steel would be suitable while being easy to cut/drill/sand flat and of course heat treat? I don’t have a heat treating oven, so a steel that I can heat treat with a simple coal forge would be awesome. |
7 replies so far
#1 posted 12-19-2018 10:37 PM |
I see O1 a lot. Don’t think heat treating is necessary. -- Shooting down the walls of heartache. Bang bang. I am. The warrior. |
#2 posted 12-26-2018 10:26 AM |
I give a list of what I used for this plane. http://www.timetestedtools.net/2016/01/26/making-the-2015-toted-infill-smoother-part-1/ Alao If you click on the “my builds” tab you’ll find some other build info. You only need heat treatment for the blade if you plan to make your own. -- http://timetestedtools.net - Collecting is an investment in the past, and the future. |
#3 posted 12-26-2018 03:50 PM |
I have used O1, 1018 and both 304 & 303 stainless when building planes. All have worked just fine, just some are easier to work with than others. 1095 should be just fine, as well, though this confuses me:
1095 is a high carbon steel, not a stainless steel. As Don and Fridge have said, you do not need to heat treat the sides and sole and wouldn’t want to if planning a dovetail construction. I can’t imagine trying to flatten hardened steel. Rest assured it will be fine. The Stanley’s and similar planes that most hand tool enthusiasts use are cast iron, which is far softer than even the annealed steel. -- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is. |
#4 posted 12-26-2018 07:28 PM |
Once you have the sides/bottom welded up, how do you intend to make sure the bottom is FLAT? You would really need a surface grinder to accomplish that. If the bottom ends up twisted as little as 1/32”, that is too much to expect sanding to flatten. |
#5 posted 12-28-2018 09:44 AM |
As MrRon mentions, a surface grinder is needed to get the bottom really flat. And, if you check around on Craigslist and Ebay, you might be able to find a small 6×12 or 6×18 surface grinder for a very reasonable amount of money, like $400-600. Keep in mind that they can also be used with different jigs for all sorts of sharpening and grinding operations. If you want to get into making hand planes, it might be a really good investment. -- Woodworking from an engineer's perspective |
#6 posted 12-28-2018 11:06 AM |
You guys are a trying to approach woodworking from a machinist perspective. A surface grinder is not necessary to get a plane flat enough to work at an extremely high level. Using a surface grinder on an infilled plane would also cause a lot more problems than it solves with the coolant getting everywhere. Many, if not most, of the best plane makers out there do not use a surface grinder for that very reason. With a very flat surface, some sandpaper and good technique, you can get a plane sole flat enough to produce see through shavings and reflective surfaces. My most recent plane build was flattened in this manner and I can take shavings that barely register on a caliper with half a thou resolution. If you don’t want to take my word and examples, Young Je, which the OP mentions, gets results without a surface grinder and for further proof, please check out Konrad Sauer’s work. He shows many of his process on Instagram and they don’t involve machinist’s equipment. -- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is. |
#7 posted 12-28-2018 12:00 PM |
I agree with JayT. -- http://timetestedtools.net - Collecting is an investment in the past, and the future. |
Forum | Topics |
Woodworking Skill Share
13136 |
Woodturning
2781 |
Woodcarving
563 |
Scrollsawing
413 |
Joinery
1865 |
Finishing
6297 |
7850 |
32515 |
CNC Woodworking
325 |
Hand Tools
6419 |
Jigs & Fixtures
1783 |
Wood & Lumber
7238 |
1613 |
Focus on the Workspace
2609 |
1265 |
Woodworking Trade & Swap
5392 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9623 |
