Meeting curved to straight mitered moulding
Forum topic by willhime posted 12-19-2018 07:24 PM 756 views 0 times favorited 3 replies Add to Favorites Watch
View willhime's profile
willhime
146 posts in 2149 days
12-19-2018 07:24 PM
Topic tags/keywords: jig question resource tip trick mahogany miter saw sander finishing joining
What’s the trick to meeting a curved moulding piece to a straight one for a 90 degree goal ? It takes me probably 5-8 times before I get something close to an invisible line and it’s still not that pretty
-- Burn your fire for no witness
3 replies so far
View squazo's profile
squazo
140 posts in 2255 days
#1 posted 12-19-2018 09:41 PM
while your straight molding is still a little bit long put it where you want it. and trace both sides of it with a fine pencil, scoring knife or what have you.
while your curved molding is still a bit long put it where you want it. It will over lap the previous two line, now also trace the curved molding. where to two sets of lines intersect are your cut points. connect the two points and that is your cut line
you can do this with 2 straight pieces as well.
try it out with 2 rulers on a piece of paper you will see what I mean.
View bilyo's profile
bilyo
962 posts in 1712 days
#2 posted 12-19-2018 11:46 PM
Your problem is that the radius of the curved piece is wrong. If your intent is to have a smooth transition at both ends, the radius must be such that the curve piece and the straight pieces must meet at the tangent points of the curve (circle segment). In doing this, your radius point will fall on the left side straight piece and be down from the top equal to the distance between the left and right straight pieces. You will then have a 45 degree cut at the top of the left piece and an 90 degree cut in the right one.
See next post.
bilyo
#3 posted 12-20-2018 12:10 AM
Here is a sketch of what I tried to describe above:
