Building a router table
Forum topic by AAANDRRREW posted 12-18-2018 05:14 PM 514 views 0 times favorited 7 replies Add to Favorites Watch
View AAANDRRREW's profile
AAANDRRREW
217 posts in 1774 days
12-18-2018 05:14 PM
Hello All.
A few years ago a buddy of mine gave me a router table he got second hand from someone. Seems like a real nice homemade table and has an area cut out for a throat plate. I never did anything with it because I did not own a router, up until last weekend when I received the Hitachi combo kit that comes with the fixed base and plunge base.
https://www.menards.com/main/tools-hardware/power-tools/routers/hitachi-reg-2-1-4-hp-variable-speed-fixed-plunge-base-router-combo-kit/km12vc/p-1444432939672-c-10087.htm?tid=-6574838772713808834&ipos=1
So, I’d like to now utilize this for my router table too, but I’m not sure what to do – so I attach the fixed base to the underside of the table? Any suggestions on throat plates?
7 replies so far
View GrantA's profile
GrantA
2107 posts in 2009 days
#1 posted 12-18-2018 05:30 PM
Congrats on the new router, you’ll love it! The fixed base gets mounted to the table. I assume you mean the plate is missing? Is it a rectangular recess in the table top? There are two common sizes, you’ll have to measure and that will narrow the choices. Post a picture and we can help you better
AAANDRRREW
#2 posted 12-18-2018 05:36 PM
Yeah, the plate is missing. I’m assuming the original owner kept his plate. I thought I had a pic handy but I do not – I’ll snap one later when I’m at home. I’ve never used a router much, and I’m sure there’s 101 things you can do with one that I didn’t even know you could. My wife is hoping I can make puzzles for our 2 year old…
GrantA
#3 posted 12-18-2018 06:18 PM
I’m not really sure how you’d make puzzles on a router table. If it helps your cause though sure you need it to round over the edges
You’re gonna want a scrolls and/or bandsaw for puzzles if you don’t already have one
View HokieKen's profile
HokieKen
11982 posts in 1740 days
#4 posted 12-18-2018 06:25 PM
You can use the router to make puzzles using templates. But that’s not really handy unless you want to make multiples of the same one…
So is there a rectangular cutout in the table somewhere around 9×13 or is it just a 1-3” round hole? If the former, then take measurements and get a router plate that fits and you’ll mount your router to that then drop that in the recess. If the latter, then you just mount your router right to the bottom of the table.
-- Kenny, SW VA, Go Hokies!!!
View bondogaposis's profile
bondogaposis
5604 posts in 2953 days
#5 posted 12-18-2018 08:50 PM
You don’t have to attach it to the table, there is another way, you can get a router plate for you router. Rockler has them, here You will need to route a recess to accept the plate into the top of the table. Then attach the router to the router plate and drop it in.
-- Bondo Gaposis
AAANDRRREW
#6 posted 12-19-2018 09:31 PM
Hey guys. See attached photos. Apologies for the mess…and the table obviously wasn’t ever finished by the original owner, but can’t complain because it was free.
The opening is 11.75”x9.25”
View WoodenDreams's profile
WoodenDreams
880 posts in 512 days
#7 posted 12-19-2018 11:20 PM
Cut yourself some MDF board to lay into the opening. Set your router base on the plate made, and mark a pattern for the router base, and the holes in the base, Drill the holes for the cowel or bit opening, and drill the hole for the flange screws or bolt to secure the router base, countersink the holes for the screws heads to be below or flush with the surface.
to , Don’t forget to screw the plate to the table, so it stationary and doesn’t wobble while routing.
