Forum topic by Goodsh | posted 12-18-2018 01:40 PM | 745 views | 0 times favorited | 6 replies | ![]() |
Topic tags/keywords: finish cold freeze cured I’ve made a small side table for my mother in law and we’re driving about 8 hours to her place for a Christmas. The finish will be dry for a day or two before we leave but won’t be fully cured and it will be below freezing for the drive. Anyone have any experience with this? Will the cold weather damage the finish in any way or just slow down the curing process? I’m using a wiping varnish – general finishes Arm-R-seal. Thanks for any advice! |
#1 posted 12-18-2018 02:02 PM |
The cold temps will slow the curing hugely, but it won’t harm anything. If you have a day or 2 of curing before leaving, you’re good to go. It will likely smell some after warming back up. -- Our village hasn't lost it's idiot, he was elected to congress. |
#2 posted 12-18-2018 02:02 PM |
As long as the finish is dry to the touch and not tacky, you should be okay. -- Bondo Gaposis |
#3 posted 12-18-2018 02:30 PM |
Once your mil has it, tell her to just let it sit in the house for another 3 weeks before using it to let the ars fully cure. |
#4 posted 12-18-2018 03:25 PM |
You’ll probably need ventilation in the car. Be prepared to crack your windows and crank up the heat. Do NOT let yourselves get woozy on the road. |
#5 posted 12-18-2018 04:03 PM |
it will be below freezing for the 8 hour drive. indicates that the table will be outside the car in some fashion ? . . -- I am a painter: that's what I do, I like to paint things. -- |
#6 posted 12-18-2018 09:42 PM |
Would not expect much smell from Arm-r seal after 2 days drying. Certainly the solvent is gone You should be fine -- “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2077 |
Finishing
6714 |
8188 |
34190 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5578 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9903 |
