Sawhorse question
Forum topic by Silverker posted 12-18-2018 03:55 AM 486 views 0 times favorited 4 replies Add to Favorites Watch
View Silverker's profile
Silverker
2 posts in 398 days
12-18-2018 03:55 AM
Topic tags/keywords: question tip
How do you determine the finished height of sawhorses? Ex: I have a 40” table, rollers will take up about an inch. So I would need a finished height of 39”. How would I figure this for “standard” A-frame sawhorses?
View Firewood's profile
Firewood
1050 posts in 2236 days
#1 posted 12-18-2018 05:44 AM
Since your table is at 40” and a typical tablesaw is closer to 36”, you might consider an adjustable design that can accommodate multiple options. A quick search will find quite a few design options. Here is the first I ran across. Hope this helps.
-- Mike - Waukesha, WI
Silverker
2 posts in 398 days
#2 posted 12-18-2018 10:00 PM
I’ve thought about that, but steered away from it because once set I wouldn’t be changing it. The 40” is just a number for an example, just not sure the actual dimension right now. I’ve also thought about folding ones like they have on the Wood magazine site, but those would have to be modified to accept the rollers that I’m looking at. I was hoping that there was a simple formula that I didn’t know about.
View GR8HUNTER's profile
GR8HUNTER
6797 posts in 1314 days
#3 posted 12-18-2018 10:38 PM
this might help you out https://www.blocklayer.com/calculatordirectory.aspx :<))
View LittleShaver's profile
LittleShaver
608 posts in 1221 days
#4 posted 12-18-2018 10:42 PM
A squared + B squared = C squared.
-- Sawdust Maker
