Questions about my 103.27270
Forum topic by DBDbj posted 12-17-2018 03:20 AM 308 views 0 times favorited 1 reply Add to Favorites Watch
View DBDbj's profile
DBDbj
1 post in 404 days
12-17-2018 03:20 AM
I noticed my Craftsman 103.27270 saw had a very loose likely original belt and went to upgrade to a link belt. However, my saw has a double pulley that is running a smaller than 1/2 inch belt.
I went to upgrade the pulleys to 1/2 inch and then lost the “key” that fits on the arbor to locate the pulleys.
So a few questions:
1. Where do I find a new key?
2. If I switch to 1/2 in pulleys, do I need a double again or is a single ok?
Thanks !
1 reply so far
MrUnix
7597 posts in 2806 days
#1 posted 12-17-2018 05:39 AM
- DBDbj
I would have just put some new belts on… given the age of the machine, they probably did need to be replaced. Also, would be way cheaper (less than ~$10) and you wouldn’t have any of the problems associated with link belts (plus, I personally try to keep the machines as close to original as possible, when possible – YMMV).
Anyway, you can get key stock (and woodruff keys) at pretty much any hardware store, Home Depot, Lowes, Menards, Graingers, McMasters, Amazon, etc…
