Bandsaw Buzz
Forum topic by skatefriday posted 12-17-2018 02:23 AM 518 views 0 times favorited 10 replies Add to Favorites Watch
View skatefriday's profile
skatefriday
453 posts in 2086 days
12-17-2018 02:23 AM
I acquired a relatively old Jet 18” bandsaw. It had been used a couple dozen times and then sat in a garage for 15 years. Took it mostly apart to clean and tune. The tires have cracks on the sides. The blade and tires had pitch spots. Cleaned all that. Cleaned the bearings. All are free rotating. However when running the saw there a distinct buzz when running the saw from the blade hitting the guide bearings.
I took the bearings off entirely and the buzz went away. Put the bottom ones on, no buzz. Put the top ones on buzz. I have confirmed that the thrust bearing is off the blade, as are the side bearings.
This is my first bandsaw that weighs over 15 pounds not made by craftsman. Is this normal? Considering replacing the tires, but the crown of the tires is relatively intact as compared to the outer edges, and I have the gullet of the blade aligned with the crown as most research indicates is proper. Also have verified tension as best I could. It is currently tensioned a bit above to 3/4” mark in the video below.
Any suggestions for what to do next?
Thanks: Video demonstrating buzz: https://youtu.be/iLsPagZJAUE
10 replies so far
View Aj2's profile
Aj2
2648 posts in 2401 days
#1 posted 12-17-2018 03:00 AM
I watched the video two things come to mind. The saw is haunted or the bearings that are making the noise are cheap and dry.
As far as the buzz goes has the saw been staying out late and sneaking back in at sunrise? :)
-- Aj
View Steve's profile
Steve
1695 posts in 1185 days
#2 posted 12-17-2018 03:18 AM
Yeah, I bet the little ball bearings inside one of the bearings are the culprit. I’d order a completely new set of all the bearings while you’re at it.
skatefriday
#3 posted 12-17-2018 04:06 AM
Thanks all.
Do you pinch the blade between the upper and lower bearings? I have it set such that the bearings are about 1/32” off the blade. When running I don’t think the bearings are moving.
View Aj2's profile
Aj2
#4 posted 12-17-2018 04:27 AM
On my pm 14 I set the bearings very close to the blade. But they don’t turn when the saw is running when I start cutting they will start to turn a little because dust builds up or pitch on the blade. If they start screaming I back them a touch even with the saw running.
I also removed the lower side bearing I found they don’t do squat but get covered with dust and pitch. The rear bearing are the most important you want the blade to contact both at the same time. On my saw this makes the most difference and good straight welded blade and the rear thrust bearings contacting at the same time.
Good luck
-- Aj
View TheFridge's profile
TheFridge
10859 posts in 2089 days
#5 posted 12-17-2018 04:28 AM
Ideally, the bearings don’t move until you apply the slightest of pressure from the front or sides.
And I’d change bearings, especially guides, on any equipment that I don’t buy brand new.
View Robert's profile
Robert
3599 posts in 2084 days
#6 posted 12-17-2018 02:02 PM
Same thing happened to mine I narrowed it down to two bearings that were pretty much seized.
Cheap enough I would just replace them all.
View jonah's profile
jonah
2092 posts in 3902 days
#7 posted 12-17-2018 04:35 PM
As mentioned above, bearings (even good ones) are so cheap I’d replace them all. Since bandsaw guide bearing are never under any real load, I’d just go with cheap ones. Figure out what kind they are, order a pack of 10 or something, and replace them all.
View bilyo's profile
bilyo
959 posts in 1706 days
#8 posted 12-17-2018 05:55 PM
Check to make sure that the guide bearings are not riding against the side of the blade teeth. They should be adjusted so that they ride against the side of the blade just behind the tooth gullets. And, make sure that the rear bearing is close enough to the back edge to keep it in that position when cutting pressure is applied.
View Andybb's profile
Andybb
2349 posts in 1207 days
#9 posted 12-17-2018 07:05 PM
I use the dollar bill trick for space between the blade and guides. Push the guides together with a bill between the blade and guides then tighten. Not very scientific but it works for me.
-- Andy - Seattle USA
skatefriday
#10 posted 12-22-2018 04:26 AM
Following up for documentation purposes. New tires, new drive belt, and a new blade have vastly reduced the buzz. The saw had sat, tensioned, in a garage for 10+ years. I think the largest contributor was the drive belt as it had established “memory” and was causing the entire saw to shake. The tires came off in pieces about 1/4” square. New urethane was tough to get on, but looks pretty once set. Saw runs much quieter now.
Thanks all.
