new small shop, ridge beam or truss
Forum topic by FyrFyter5 posted 12-16-2018 04:40 PM 701 views 0 times favorited 7 replies Add to Favorites Watch
View FyrFyter5's profile
FyrFyter5
1 post in 408 days
12-16-2018 04:40 PM
I am moving my shop out of my basement into about a 350sqft addition to my existing garage. I will be doing the work myself so labor costs and the time to construct it arent a big factor. What are your thoughts on a truss vs ridge beam for roof construction? I am leaning toward a ridge beam because of added ceiling height and I think it can allow higher storage and the shop will feel bigger. The top of the wall will be at 10 feet. Any benefit for using a truss?
Thanks!
7 replies so far
View muleskinner's profile
muleskinner
941 posts in 3048 days
#1 posted 12-16-2018 05:11 PM
I end up storing lumber in the trusses.
-- Visualize whirled peas
View bondogaposis's profile
bondogaposis
5613 posts in 2963 days
#2 posted 12-16-2018 05:51 PM
There is nothing wrong with either construction method as long as the framing members are sized correctly for the spans and account for snow loads in your area. I personally prefer ridge and rafter construction if I am doing the work myself, because moving trusses usually requires a crane or at the very least more than one person.
-- Bondo Gaposis
View Phil Soper's profile
Phil Soper
25 posts in 413 days
#3 posted 12-16-2018 07:08 PM
I would suggest a ridge beam with collar ties in the upper third. A suspended ceiling just below the rafters makes for a high open area. Here is a photo of mine, the walls are 9’ and the peak is at 14’.. This photo was taken during a dovetail class
View tomsteve's profile
tomsteve
990 posts in 1831 days
#4 posted 12-16-2018 09:18 PM
speed of getting roof on and enclosed is a benefit of trusses. gables are easier to close up and trusses set quick. you could look into scissor trusses to give you that vaulted ceiling,too.
View WhyMe's profile
WhyMe
1209 posts in 2172 days
#5 posted 12-16-2018 11:20 PM
Doing stick built yourself you may find it cheaper to do ridge beam and rafters than buying truss.
View Roy Turbett's profile
Roy Turbett
169 posts in 4191 days
#6 posted 12-17-2018 03:12 AM
I went with scissor trusses on my 30×40 shop with 8’ walls. The pitch is 8/12 on the outside and 5/12 on the inside. This gives me 16’ at the peak. I have a 20’ long radiant heat tube that is suspended from the center and provides excellent even heating. Combustion air is drawn in from one gable and exhausted out the other. I also have a 8’ deep loft on one end of the building for lumber storage.
View Bill Berklich's profile
Bill Berklich
1004 posts in 1000 days
#7 posted 12-17-2018 04:33 PM
I went with scissor trusses on my 30×40 shop with 8 walls. The pitch is 8/12 on the outside and 5/12 on the inside. This gives me 16 at the peak. I have a 20 long radiant heat tube that is suspended from the center and provides excellent even heating. Combustion air is drawn in from one gable and exhausted out the other. I also have a 8 deep loft on one end of the building for lumber storage.
- Roy Turbett
+1 on the Scissor Truss. Much easier to install, much less work, fewer cuts, less fitting and finicking, etc. you’ll have more time to work on the rest of the envelope
-- Bill - Rochester MI
