Best Wood Blanks
« back to Woodturning forum
Forum topic by wwwanabe posted 12-16-2018 04:33 PM 806 views 0 times favorited 13 replies Add to Favorites Watch
View wwwanabe's profile
wwwanabe
34 posts in 2003 days
12-16-2018 04:33 PM
Brand new to turning….have the nova 2 system with 4 jaw chuck, Benjamin Best starter set of tools. Tools seemed to have dulled quickly so about to buy the Rion Slow Speed grinder white white wheels and the One way system with Varijig. Both items from Amazon are $140 each.
Now for the obvious question. Where is the place to by turning blanks? My “practicing” with glued together rough 2x lumber is not working out so well. It usually breaks or comes out very rough.It’s probably me catching the wood or doing something else wrong.
Lastly, can I save money and use the 3450 regular bench grinder I have and save some money? I would have to add the white wheels of course.
Any help or advice would be appreciated.
13 replies so far
View John Smith's profile (online now)
John Smith
2502 posts in 963 days
#1 posted 12-16-2018 04:58 PM
have you looked on E-Bay for turning blanks ??
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
wwwanabe
#2 posted 12-16-2018 05:56 PM
Thanks. No I haven’t tried ebay but can look into it. What’s the best, easiest turning wood to get started with?
View Andre's profile
Andre
3622 posts in 2607 days
#3 posted 12-16-2018 05:59 PM
Best, cheapest scrap hardwood and cut your own blanks. Pay attention to growth rings small burls, learn how to read the wood. Stick with slow speed grinder which is still too fast, if you can’t touch the metal it’s to hot!
View Steve's profile
Steve
2107 posts in 1383 days
#4 posted 12-16-2018 06:30 PM
Plenty of free blanks in the woods.
View EricTwice's profile
EricTwice
248 posts in 1334 days
#5 posted 12-16-2018 06:47 PM
high speed steel is not effected by heat so a high speed grinder is fine. If you are new to turning, junk wood is better than buying stuff and then throwing it away. A friend (and fine turner) recommends scrap framing timber also firewood works well. Is there a cabinet shop nearby that will let you go through their scrap pile.
You will like turning green (freshly cut and wet) wood. Framing timber is a pain but if you can turn it you can turn anything.
Have fun
-- nice recovery, They should pay extra for that mistake, Eric E.
View LesB's profile
LesB
2568 posts in 4244 days
#6 posted 12-16-2018 06:56 PM
Another alternative for sharpening is one of the belt sander sharpening set ups.
I use a 3450 rpm grinder with a white 100 grit disk. You just have to work lightly and watch for heat build up…the steels turns blue… Try keeping a container of water next to the grinder to cool the tip as you work. The hardest part is getting the correct angles, especially on gouges. There are lots of articles on sharpening and making jigs to get the correct angles.
You might consider getting a set of the carbide tipped tools which keep their edge for a long time. You can rotate the tips for a new edge and they can be resharpened (some) with a diamond sharpening stone (on their flat side). I find they are great for roughing out the blank but they do not cut as finely as high speed steel so I do my finish cuts with that.
Most of my blanks come from salvage wood (some is actually firewood). I collect it where I can and once you friends find out you want it they usually start saving it for you. Then you need to decide whether to turn them while wet or chance letting them dry and possibly developing cracks…this is a whole new topic for discussion. I particularly like fruit wood, apple, apricot, and plum are great. So you may need a chain saw, and a band saw to cut the blank to shape. For small stuff a sawsall (reciprocating saw) with a long coarse blade will also work for both cuts.
For mounting wood with your lathe chuck. I use a router with a dove tail bit and a template guide. Make a template out of 1/2” plywood, cutting circles the proper size in the plywood, then clamp it over the blank and routing a recess (dado) about 3/16 to 1/4” deep to fit the chuck. For bowls or hollow turnings I cut the recess into the side that will be hollowed out, the top. I then turn the bottom and outside (including most of the sanding); in the process i make a new recess (you could also cut a spigot instead), for flipping the turning over and remounting it to finish turning the inside. On very soft wood you may need a deeper recess but your are limited by the size of your chuck jaws. I have been doing this for years without a problem and it speeds up the mounting process…no mounting plate,.no glue, & no screws. I have a blog on this web site with pictures if you are interested.
-- Les B, Oregon
View bigJohninvegas's profile
bigJohninvegas
788 posts in 2263 days
#7 posted 12-16-2018 07:18 PM
Just about anything you can find for free, local wood works fine to start learning on.
Catch local tree trimmers. they will normally just give it away. firewood works well to.
Even 3 to 4” limbs have a use. I will still pick up a limb. make it round and practice beads and coves.
teaches great tool control. When it gets to small throw it in the fire pit and grab another limb.
Keep your eye open for it too. Some local wood, fire wood will give you great projects.
-- John
wwwanabe
#8 posted 12-16-2018 07:20 PM
Have fun
- EricTwice
Thanks for the response…..maybe I just need to keep at it and get some better scraps to glue up..like oak or cherry
wwwanabe
#9 posted 12-16-2018 07:23 PM
- bigJohninvegas
Thanks John…..more good ideas….it’s very tempting to buy store bought blanks from say Rocker but maybe I need to crawl first.
wwwanabe
#10 posted 12-16-2018 07:27 PM
Have fun
- EricTwice
- wwwanabe
- LesB
Thanks Les. So I can use my old 3450 grinder just need to be careful with the blueing. I’m am going to get the One way system from amazon which should help with the angles. Also, thanks for the detailed response…...I’ve got a got to learn that’s for sure. Maybe I should have started with pens….lol
View Phil32's profile
Phil32
1073 posts in 704 days
#11 posted 12-16-2018 07:37 PM
Your questions touch on several aspects of woodturning. Perhaps you need a mentor (an experienced turner) to walk you through some of the basic ideas. Otherwise you will go through a lot of trial and error. Our local Woodcraft store offers beginning classes. We also have a local woodturners club. When I started turning (as a teenager), my uncle helped me through the basics. We worked with solid chunks of various trees. Glue-ups came much later.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
View Andybb's profile
Andybb
2783 posts in 1404 days
#12 posted 12-16-2018 08:45 PM
The easy answer is that Rockler and Woodcraft both usually have bins full of round dry turning blanks of various species for less than $10 but I don’t know if they are in your area. I save the cutoffs from our xmas trees every year. There’s also nothing wrong with working with the glue ups you were using and developing your technique so that you don’t get catches etc.
-- Andy - Seattle USA
View LeeMills's profile
LeeMills
702 posts in 2102 days
#13 posted 12-18-2018 08:00 PM
JMO but you can use your current grinder. I guess an 8” slow speed with $150 wheels would be nice.
I use a setup I built back in the 80’s and it still works fine. Tools still get sharp with about 120 grit and 6”.
I don’t know where you live but maybe check with firewood guys. Probably sell you some real cheap or give you some.
Also you may want to call your local power company to find out who does their trimming for the line. Locally they grind limbs or trees over 6” but that’s it. Over 6” they stack for the homeowner to dispose of.
Also check craigslist for free wood (normally listed as firewood). Just checked my local listing and there are 81 listings current for free firewood.
