Forum topic by FirePro | posted 12-14-2018 08:54 PM | 869 views | 0 times favorited | 1 reply | ![]() |
Hello All, I am gearing up to build a set of mid-century modern style furniture for the whole house. Everything will be very clean, simple and square and made from 3/4” walnut veneer plywood with 1/4” solid walnut faces. Any doors or drawers will be flush with the face. I finish most pieces with at least a very small round-over on any exposed edges. Is this still a good idea for this style? Or should I just knock down the corners with a sanding block or burnish with the shaft of a screwdriver? Thanks in advance! |
