Barrister Bookcase stacking techniqes
Forum topic by jwnpgh posted 12-14-2018 02:49 PM 631 views 0 times favorited 7 replies Add to Favorites Watch
View jwnpgh's profile
jwnpgh
4 posts in 681 days
12-14-2018 02:49 PM
Topic tags/keywords: barrister stacking hardware
Hi
I would like some advice. i am building a barrister bookcase, and have seen many in person, inspected the joinery and hinges and stacking techniques.
I decided to build simple boxes, with uniform and smooth tops and bottoms. i thought i would use brass dowels and sleeves for stacking accuracy and stability. however, it is proving hard to line them up accurately.
does anyone have any ideas for doing this? I would like to achieve accurate line up of sides and fronts, and stability.
any advice is appreciated.
thanks
John I can post a photo if that helps, of them simply stacked
7 replies so far
View EugdOT's profile
EugdOT
316 posts in 1437 days
#1 posted 12-14-2018 03:24 PM
Maybe this can help
https://youtu.be/XmH8rBorj2Y
View socrbent's profile (online now)
socrbent
1016 posts in 3151 days
#2 posted 12-14-2018 06:46 PM
View John Smith's profile
John Smith
2722 posts in 1045 days
#3 posted 12-15-2018 12:32 PM
the Barrister is my favorite office type furniture.
looking forward to following your project.
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View therealSteveN's profile
therealSteveN
6442 posts in 1456 days
#4 posted 12-15-2018 12:47 PM
Hi
thanks
- jwnpgh
The simplest way to locate a dowel is to use Dowel points, or Dowel centers as easy to use as anything in woodworking.
Drill holes on the top of the bottom piece where you want them. For uniformity I would make a template of some 1/8” hardboard so they stay uniform. After the holes are in, pop in a dowel center on each hole.
Then very gently sit the box to be on top, over the centers. Once you are exactly where you want it press down to place pinpricks into the wood. I have found with some woods it’s hard to pick up the pin pricks after they are placed, so first try it on some scrap from the project.
If you can’t clearly see them, either a white grease pencil, or heaven forbid, steal some of the Wife’s lipstick, and very gently make a mark with the “color” agent to highlight where your pin pricks are. The pin pricks are your drill placements.
Take your time, and it’s foolproof. Go too quickly, and make too many marks, and it can be problematic, but transference is the best way to locate something, and with dowel holes this is the best way.
Look forward to seeing your cases.
-- Think safe, be safe
jwnpgh
4 posts in 681 days
#5 posted 12-16-2018 06:58 PM
Maybe this can help
- EugdOT
This video served as my inspiration. I liked the way they stacked their sections, but wanted something different. Thanks :-)
jwnpgh
4 posts in 681 days
#6 posted 12-16-2018 07:03 PM
- therealSteveN
I tried this without the jig, hence my post here. i suppose this is the best way.
I appreciate the input guys, thanks :-)
jwnpgh
4 posts in 681 days
#7 posted 12-16-2018 07:04 PM
here is an in progress photo, for those interested, and again thanks for the advice :-)
