Rockwell Unisaw 34-466 arbor bearings size
Forum topic by CVN72 posted 12-13-2018 06:26 PM 560 views 0 times favorited 3 replies Add to Favorites Watch
View CVN72's profile
CVN72
13 posts in 621 days
12-13-2018 06:26 PM
Hi,
The Rockwell Unisaw manual for the 34-466 lists two arbor bearings, SP-5344 (.6693×1.5748x.563) and SP-5335 (.6693×1.5748x.4724). The 6203 bearing is sized for the SP-5335 bearing. I do not see a bearing that matches the SP-5344 bearing in the Accurate Bearing Company catalog. Will two 6203 bearings work?
Thanks.
3 replies so far
MrUnix
7595 posts in 2805 days
#1 posted 12-13-2018 08:58 PM
At some point in time, Delta switched from bearings with an extended inner race (88503) to more standard bearings without the extended race (6203). Pull the ones you have now and see which ones you need. They should have the number stamped on the side and you can take measurements to verify.
CVN72
#2 posted 12-13-2018 09:34 PM
OK, I was hoping to not have to pull the bearings before ordering new ones, but that looks to be the safest way.
Thanks for the information.
View TheFridge's profile
TheFridge
10859 posts in 2093 days
#3 posted 12-14-2018 03:03 AM
Unfortunately. It’s how it works out all the time.
