Table Saw Noise
Forum topic by Monty151 posted 12-13-2018 05:48 PM 560 views 0 times favorited 8 replies Add to Favorites Watch
View Monty151's profile
Monty151
85 posts in 452 days
12-13-2018 05:48 PM
Topic tags/keywords: tablesaw
Hey all,
I have been working with my newly acquired Craftsman 152.221040 and all has been pretty smooth. One thing that is an issue is that when I lower the blade there is an awful squealing noise. It doesn’t squeal when lifting just lowering. I have blown out all the dust that seems to have accumulated over time and since doing that it has gotten worse.
Any suggestions on how to remedy this would be appreciated. I almost have to wear ear protection to lower the blade it is so bad.
Thanks
8 replies so far
View mrg's profile
mrg
860 posts in 3610 days
#1 posted 12-13-2018 05:50 PM
Spray some dry lube on the shafts and metal that rubs, should take care of the issue.
-- mrg
View Phil32's profile
Phil32
855 posts in 514 days
#2 posted 12-13-2018 10:23 PM
I would guess it is something more than lubrication, perhaps a blade that is too big (diameter) for the saw and contacting the blade housing.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
Monty151
#3 posted 12-13-2018 10:47 PM
I thought that may be the issue Phil however it still squeals without a blade installed. I will try what mrg suggested. I may have to get in there with some more air to try to blast any lingering saw dust there may be. After that shooting some dry lube and see if that help.
Thanks for the help gentlemen
MrUnix
7601 posts in 2810 days
#4 posted 12-13-2018 10:56 PM
Just needs lubrication. Dry lube, paraffin wax, etc… stay away from grease or any ‘wet’ lube that will attract sawdust.
View Richard Lee's profile
Richard Lee
260 posts in 1386 days
#5 posted 12-13-2018 11:25 PM
Just needs lubrication. Dry lube, paraffin wax, etc… stay away from grease or any wet lube that will attract sawdust.
- MrUnix
I went thru this with my saw, could not get the grinding squeeling to quit tried every dry lube out there. Didnt last more than a week,so I finally greased the sector and worm,been good for months now with no problems. SawStop actually recommends greasing the said parts every 6 months, the sawdust seems to get wiped away and is alot softer than the cast iron and wont hurt anything.
Taken from sawstop manual.
Elevation and Tilt Mechanisms:
The elevation and tilt gearing should be kept clean and well lubricated. Periodically check the condition of the
elevation miter gears and threaded shaft, and the tilt worm gear and sector gear. If necessary, clean off any dust, dirt, pitch or other debris using a wire brush, and then reapply a good quality, non-hardening grease.
Page 68
https://www.retsd.mb.ca/WSH/procedures/All%20Procedures/MAN-0736%20Saw%20Stop%20Table%20Saw%20CB51230%20Manual.pdf
Monty151
#6 posted 12-14-2018 02:14 PM
Thanks for the input. Would it hurt anything to use some PB blaster to clean the grime off and then hit it with the non-hardening grease?
Richard Lee
#7 posted 12-14-2018 05:58 PM
PB is a penetrating oil, not a cleaner. But dont think it will hurt.
Monty151
#8 posted 12-14-2018 06:41 PM
Thanks Richard, I knew it wasn’t a cleaner, however I just cleaned up the cast iron top so I figured I’d use what I have on hand.
Thanks for the input guys
