Would like input into saw purchase
Forum topic by Sawnglue posted 12-13-2018 04:18 PM 510 views 0 times favorited 13 replies Add to Favorites Watch
View Sawnglue's profile
Sawnglue
4 posts in 403 days
12-13-2018 04:18 PM
I currently have a Jet Shop Pro table saw that I’ve had for a few years. I have the opportunity to either upgrade to a 3hp Sawstop cabinet saw OR keep my Jet and pick up a Festool TS55 track saw and accompanying tracks and clamps. I see huge benefits of both, and would like others input…what would you do. WWYD??
-- Gary, Houston
13 replies so far
View johnstoneb's profile
johnstoneb
3131 posts in 2776 days
#1 posted 12-13-2018 04:39 PM
Go with the Sawstop. The tracksaw is primarily for plywood clamps and a straight edge and skilsaw can do that.
-- Bruce, Boise, ID
View Brawler's profile
Brawler
99 posts in 434 days
#2 posted 12-13-2018 04:43 PM
Yeah I agree with Bruce, and sawstops are great machines.
-- Daniel
View GrantA's profile (online now)
GrantA
2114 posts in 2011 days
#3 posted 12-13-2018 04:46 PM
I think the table saw upgrade would be great BUT it depends what type of work you do. I’d love to get a track saw for crosscutting panels
View Andybb's profile
Andybb
2349 posts in 1207 days
#4 posted 12-13-2018 04:53 PM
Welcome to lj Gary.
People seem to like the WEN track saw that comes with 2 guide rails for $125. Or you can make a track saw.
You can’t make a Sawstop.
Get the Sawstop.
-- Andy - Seattle USA
View ArtMann's profile
ArtMann
1462 posts in 1419 days
#5 posted 12-13-2018 04:54 PM
That is a tough one. I hope you know that you are the best person to answer that question. I will say that after 35 years of using a circular saw and home made plywood saw guide, I got a real track saw. It is easier to use and the cut quality is better. I use my track saw primarily for cross cutting sheet goods. If you don’t do a lot of that, then the Table saw might be the better choice.
View redham's profile
redham
50 posts in 1053 days
#6 posted 12-13-2018 06:17 PM
The most important question… what type of woodworking do you do? What is your budget?
Generally… if you do straight woodworking in a large shop then a good 3hp+ ts would be the core tool you should spend your money on
A track saw is great for onsite and shop breakdowns of 4×8 sheets as well as percise trims onsite.
Its goes down to how much usage you will get from either one and how good of a deal your getting for those tools.
View knotscott's profile (online now)
knotscott
8354 posts in 3979 days
#7 posted 12-13-2018 06:18 PM
Saw Stop. It’s a clear upgrade, plus it won’t bite the hand that feeds it.
View jonah's profile
jonah
2092 posts in 3902 days
#8 posted 12-13-2018 06:43 PM
I use my track saw infrequently (I have a clone of the Grizzly/Wen one I got five or six years ago). I find it useful, but I don’t do a ton of work with sheet goods. I’m much more likely to be working with solid wood, and track saws are of limited utility there.
I vote Sawstop. Sock a little money away and pick up a track saw later (the Festool is great, but it’s only incrementally better than the cheap ones).
View clin's profile
clin
1075 posts in 1599 days
#9 posted 12-13-2018 06:51 PM
Unless you have a specific need for the track saw, I’d go with the new table saw. A table saw is a much more general purpose tool. I also have a 3 HP SawSaw PCS and it is a great saw.
I breakdown sheet goods with a circular saw and a clamp-on straight edge. However, I don’t try to make finish cuts that way, just get things to approximate size. Then I make the final cuts on the table saw.
-- Clin
Sawnglue
4 posts in 403 days
#10 posted 12-13-2018 07:20 PM
Thanks for your input! I’m leaning towards the table saw upgrade.
-- Gary, Houston
View MPython's profile
MPython
208 posts in 416 days
#11 posted 12-14-2018 12:44 AM
Sorry. Late to the party.
I have both – a Sawstop cabinet saw and a Festool track saw. My shop is small. I use the track saw to break down sheet goods in the yard before I bring them into the shop. I do this three or four times a year. I use my Sawstop every day. I suppose one could use a track saw instead of a cabinet saw, but I would never consider it. Being able to walk over and turn on a quality, heavy duty machine that will cut just about anything I want to cut precisely and accurately far outweighs the hassle of setting up a track saw to make a simple cut.
Sawnglue
4 posts in 403 days
#12 posted 12-14-2018 01:23 AM
Sawstop it is! I appreciate everyone’s input!
-- Gary, Houston
View BurlyBob's profile
BurlyBob
6895 posts in 2869 days
#13 posted 12-14-2018 01:53 AM
Smart move.
