12-13-2018 04:17 PM
Topic tags/keywords:
oak
finishing
Ok I’m making my first table top. First time working with Red Oak. I had some trouble staining.It kept bleeding back and it was cold so it was taking forever. I eventually laid towels on it and some plywood for weight to soak up what came up. Worked great. I wanted it darker. I sanded down the bottom to try it.I restained it after 8 hours of sanding with a belt sander!!! It was super blotchy. Went from 50 grit to 80 to 100 to 150…just blotchy as heck. So I decide I wasn’t going to try to sand the top or it would end up looking like the bottom. SO I just accepted the color. I didn’t do any cutting or wood working in the shop for a week to let dust settle.
Fine. Wiped table top with wet cloth. Now I tried to use Minwax polyurethane satin, fast drying. The stain had been drying for nearly two weeks. It was dry. First time I applied the polyurethane, I used a polyester brush and straight polyurethane without any mineral spirits. Wiped with damp cloth before. I got crazy bubbles. I then sanded with 220 grit. It sanded smooth but I could see where the bubbles had been.
So the first picture is trying again but with a natural china brush and putting about 10% mineral spirits, long slows strokes. I even soaked the brush in mineral spirits to let all the bubbles escapes and wiped slowly on newspaper to get the mineral spirits off before applying the polyurethane to the table top. As you can see it bubbled like crazy again, so I wiped off before it could dry. AHHHHH! DO I just need to sand more? I can see where the bubbles were but I cant feel them. I tried to take a picture of it but you cant see it in the second picture.
Ive read as much as I could but I don’t know what my mistake is. Temp is around 50 degrees. Please Help! This is supposed to be a Christmas present.
I will say it looks like there is still bad polyurethane on it so I may have to sand it even more, its just hard to see in the picture. Second attempt still wet.
After first attempt sanded down.
Got mad and started sanding more with 220 grit. Now its hazy, I hope I didn’t mess up the stain.
16 replies so far
#1 posted 12-13-2018 04:59 PM
Temperature is most of your problem. Finish is too cold to release the air bubbles, Get it up in the 60’s. Try a foam brush and lay it on in one direction, don’t brush back and forth. The haziness is just the sanding of the gloss off the finish. You may have to put several coats sanding between coat to get the bubble pockets filled from the first coat. You need to get the temperature up.
I am not a fan of Minwax esp. their polyshades but I just finished a desk with Minwax polyurethane semigloss and it came out really nice. It took about 5 coats total on red birch to get the thickness and coverage I wanted. I used cheap foam brushes and had no problems with bubbles air temp in shop was low to mid 60’s. I would use the Minwax polyurethane again.
-- Bruce, Boise, ID
#2 posted 12-13-2018 05:06 PM
Thin your poly 50-50 with MS or turpentine, ditch the brush, and use it as a wipe on. Agreed with above though, cold temps are your only real issue.
-- I've quickly learned that being a woodworker isn't about making flawless work, rather it's fixing all the mistakes you made so that it appears flawless to others! Jay - FL
#3 posted 12-13-2018 05:52 PM
If the temps are good and the product is thinned properly, any bubbles will work out before things set up.
Try it on a scrap (where you get similar bubbles) and just let it dry without messing with it. If the bubbles disappear, your project should react similarly. If the bubbles remain after drying, try to up your application temp to at least the high 60’s
#4 posted 12-13-2018 05:54 PM
Next time you wipe it off, use a cloth dampened with mineral spirits, not water. It takes a lot of time for the moisture to go away. IDK what your timing was but that could have helped it trap moisture.
Last pic looks like you may have sanded into the stain, try wiping some poly on a small spot and see if the color comes back, if not you may try re-wiping a stain coat over it and see what it does, or you’re going to have to resand it all.
Stay off of it with the 50 and 80 grit paper. 100 should be rough enough to take down anything you need to. (looks like you took a framing hammer to it?)
#5 posted 12-13-2018 06:41 PM
I’ve had this happen with red oak too. I think the solution will be to thin the polyurethane and use it as a wipe on poly. You might also try a couple seal coats of shellac over the stain? Sometimes I think the big open pores of red oak contribute to the bubbling. Maybe if you can fill them a bit with shellac it’ll help.
The stain doesn’t look blotchy to me, I don’t think. That’s what red oak looks like when it’s stained. If you want more even color between early wood and late wood rings, try a dye or a toner (shellac with dye in it). Not sure a straight dye would go well over a stain – usually you’d dye first.
If you can’t bring the project somewhere where it’s warmer, maybe try to use a water based finish instead? Polycrylic can look really nice, and goes in fine over an oil based stain as long as it’s fully cured/dried. You could also do a seal coat of shellac before the polycrylic if you’re concerned about the stain not being fully cured. Shellac is great stuff.
#6 posted 12-13-2018 06:48 PM
Also keep in mind that you will not get a smooth flat furniture showroom finish on Oak without filling the pores, it is impossible to get a flat surface thinking that each poly coat will eventually fill in the pores and the surface will self level DAMHIKT
#7 posted 12-13-2018 08:51 PM
+1 on previous post (ChefHDAN)
Oak is a porous grain wood. You cannot achieve a glossy, flat tabletop without filling the grain.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit! Likewise with woodworkers.
#8 posted 12-13-2018 08:55 PM
I sanded that damn top for almost a month before I gave up, wish I had LJ back then…
#9 posted 12-13-2018 09:01 PM
You can get a flat surface with numerous coats of finish on red oak but it takes a very long time. Much easier and faster to use a filler first.
-- Bruce, Boise, ID
#10 posted 12-14-2018 03:00 AM
Awesome! Thanks for the feedback! I feel confident in trying again. I’m actually going to break out my router sled and plane it down. One because I did end up sanding to much now the stain is uneven and blotchy. Also, there were a few sanding marks show up after the stain so I kind wanted to go darker.
So I’m going to plane it down. I just hope I can plane enough before I hit any pocket hole screws. I’m fairly certain I’ll be fine. Then I’ll try your suggestions. I’ll put some space heaters in the shop. Warmer temps ( how warm 80°?), thin 50/50 instead 10/90, wipe on with foam applicator, and maybe apply shellac before the poly. Did Imiss anything.
Also, yes, I was going for lightly distressed. I wanted a few marks here and there. There’s more the camera doesn’t see but I like it.
#11 posted 12-14-2018 03:28 AM
Also, yes, I was going for lightly distressed. I wanted a few marks here and there. There s more the camera doesn t see but I like it.
- Brokenanew
Sometimes when I get mad, I end up with the distressed look, so, was just checking. :)
#12 posted 12-14-2018 11:31 AM
So I m going to plane it down. I just hope I can plane enough before I hit any pocket hole screws. - Brokenanew
DOH!!!!!!
#13 posted 01-02-2019 02:50 AM
Ok. HereswhrreIm at. After planning then sanding, stain. Went on well. I’m going to wait for a few days to make sure the stain drys. Next would be something to help fill the pores before polyurethane? I saw shellac was suggested. I’ve never used it. Any type I should look for? Any tips and tricks to keep in mind?
Thanks so much for the help!
#14 posted 01-02-2019 02:51 AM
Ok. Heres where Im at. After planning then sanding, stain, went on well. I’m going to wait for a few days to make sure the stain drys. Next would be something to help fill the pores before polyurethane? I saw shellac was suggested. I’ve never used it. Any type I should look for? Any tips and tricks to keep in mind?
#15 posted 01-02-2019 03:02 AM
Ok… Are you sure they were bubbles in the finish and not dust? Did you wipe down the board with a tack cloth or a micro fiber cloth to remove all the sanding before applying the finish? Looking back at the original pictures I’m not so sure that they were bubbles at all.
I don’t think you should be having so much trouble – people put poly on oak every day. It shouldn’t need much fussing over. Just make sure the workpiece is clean, don’t shake the can of finish, and do nice even strokes with the grain.
I’d recommend doing a test board – sand some scrap just like you did the top, and apply some poly. See what happens. I don’t think shellac is necessary – I just suggested that if you decided to use polycrylic since its water based.
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12690 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2569 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
514 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
377 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1659 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
5770 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
7375 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
30717 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
268 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5984 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1624 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6836 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1515 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2414 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1230 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5145 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2320 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9345 |
