New Dewalt saw popping breaker at startup
Forum topic by CrankAddict posted 12-11-2018 01:18 PM 2915 views 0 times favorited 26 replies Add to Favorites Watch
View CrankAddict's profile
CrankAddict
139 posts in 1132 days
12-11-2018 01:18 PM
Hello,
I’ve got a brand new DWE7491RS plugged into an outlet on a 20A circuit. The outlet is 5’ from the main electrical panel. Nothing else including the lights is on this same circuit, only the garage outlets and this is the only thing running. Almost like clockwork it pops the breaker every other time I try to turn the saw on. No problems even under load once running. I can even turn on the shop vac and other things after the saw starts. If I flip the breaker and try again and it works fine. 5 minutes after shutting it off I try to turn it on again, pop. Reset breaker, works again. Try once more, fails again.
I bought a new 20A breaker today just in case that was flaky and that didn’t change anything. Still every other time it pops. I understand that startup creates a current spike, but this thing is supposed to be used on job sites with extension cords and all that, so I’m not sure how I can be having so much trouble with a 20A circuit. Does this point to a factory defect in the saw/motor itself? Some kind of binding or something like that?
Thanks!
Jeff
26 replies so far
View dhazelton's profile
dhazelton
2839 posts in 3627 days
#1 posted 12-11-2018 02:07 PM
Is it an AFCI breaker? Did you try a different circuit to see if it’s the saw or the circuit itself? Nothing is loose in the receptacle? Are you sure the wire size matches the breaker size?
Also, how cold is it in the shop? If I use my oil filled compressor in super cold conditions it’ll trip the breaker.
View RobHannon's profile
RobHannon
347 posts in 1861 days
#2 posted 12-11-2018 02:12 PM
I would try another circuit just to rule that out. Preferably on one that is not AFCI/GFCI. Also check the brushes on the saw and make sure they look good.
dhazelton
#3 posted 12-11-2018 02:15 PM
Googled and this showed up – I never knew about them.
CrankAddict
#4 posted 12-11-2018 02:26 PM
It is not an AFCI breaker. I.e. no pigtail wire, just a single black wire connection. Square D 20A breaker, but not the HM style (never knew about that either, will have to see if I can find one).
The garage doesn’t have any other circuits for me to try. So my only choices would be to carry the saw into the living room or run a long extension cord. The second option I figured would skew the results and the first is not going to pass the wife test ;)
As far as the motor brushes, not really sure what I’m looking at/for in that regard, but I can do some googling.
Really appreciate all the input!
dhazelton
#5 posted 12-11-2018 02:31 PM
Brand new saw, assume brushes are perfectly fine. Dewalt chop saws and some metal cutting saws seem to require a high initial inrush of current. Another solution that seems to work for people is switching the breaker to a two pole type.
CrankAddict
#6 posted 12-11-2018 02:47 PM
I found a local place that just ordered me a 20A HM breaker, should be here in a week. The description from Square D says “High magnetic trip circuit breakers are recommended for applications where high initial inrush current may occur.” The fact that they make a separate variant with that description would imply that the normal breakers are not ideal for this situation, so hopefully this is the fix…
Will report back if this does/doesn’t cure it, thanks again!
View Robert's profile
Robert
4827 posts in 2811 days
#7 posted 12-11-2018 04:10 PM
Did you add the breaker or was it already there? It should be 12ga wire so make sure of that. I think 14ga is the standard in residential homes now. If it is 14 that will be an issue.
When we put an addition on my house they wired it with 14ga. My miter saw tripped the breaker everytime.
CrankAddict
#8 posted 12-11-2018 04:28 PM
The circuit was already there (and it was 20A from the builder, I didn’t just put a bigger breaker in). House is only 3 years old, everything wired by an electrician. I can’t say for certain what gauge the wiring is, but with the outlet literally 5’ from the panel (also in the garage) even if it were one size too small I can’t imagine that being a deal breaker on such a short run. Since it was all wired by a pro and my understanding is that 20A circuits require 12ga wire per code, I wouldn’t think it could have passed inspection with 14ga. But I suppose it is another thing to double check… thanks.
CrankAddict
#9 posted 05-20-2019 10:33 PM
I wanted to follow up on this now that I have a few months of testing under my belt. The high magnetic breaker 100% solved the issue. Not sure if other brands (mine is Square D) make an HM breaker as well, but I would have been pretty out of luck if I was stuck with the standard 20A breaker so it’s been a real lifesaver. It went from popping every other time on start up, to not having popped once since the new breaker.
View PCDub's profile
PCDub
346 posts in 1575 days
#10 posted 05-21-2019 12:40 AM
Thank you for following up with your solution! Very helpful.
View DannyW's profile
DannyW
360 posts in 1128 days
#11 posted 05-21-2019 12:52 AM
Great to know about the HM breaker fixing the issue, but unfortunately they won’t fit into my box (I checked). My miter saw tripped the breaker every time on the 15A circuit that I wanted to use, so I had to move it to the other side of the shop (garage) to a different 20A circuit and all is well. Wish I had that option, but glad you did.
-- DannyW
CrankAddict
#12 posted 05-21-2019 12:56 AM
Danny, what brand of breaker box do you have? I ask because the Square D HM breaker I got is 100% identical in size to their normal 20A breaker. It’s almost impossible to tell them apart, I think there is one place where a faint “HM” was written on it. I was actually nervous after taking it out of the box that I’d get confused as to which was which lol.
DannyW
#13 posted 05-21-2019 12:31 PM
It is a Square D but when I looked up the HM breaker my style of box was not listed. I don’t remember exactly the name but it had Home in it (Homeline maybe?). Perhaps it will fit but they don’t list it as fitting.
-- DannyW
View JayT's profile
JayT
6440 posts in 3542 days
#14 posted 05-21-2019 12:44 PM
Danny, Square D has a couple styles of breakers seen frequently in homes—QO is one, Homeline is the other. They show Homeline High Magnetic breakers, model HOM115HM for 15amp and HOM120HM for 20 amp.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
CrankAddict
#15 posted 05-21-2019 01:20 PM
Yes, the Homeline series is what I have. The breaker p/n I got was the HOM120HM. Best $6 I ever spent! :)
