Jet table saw alignment, new member
Forum topic by Alexbringsthewood posted 12-10-2018 08:10 PM 779 views 0 times favorited 16 replies Add to Favorites Watch
View Alexbringsthewood's profile
Alexbringsthewood
11 posts in 684 days
12-10-2018 08:10 PM
Topic tags/keywords: blade alignment jet proshop
First of All let me say that I am very new to woodworking. Over the past three years I’ve collected a few nice pieces of equipment but still consider myself a novice.
That said I have a Jet proshop table that i am trying to tune.
I have read probably hundreds of forums about aligning the miter slot to the blade. I have a harbor freight dial that I have attached to my miter gauge and feel that I am 5000s of an inch out on the back.
The problem i am having is that when i return the dial back to the starting point (to ensure repeatability and that i am accurate), its always way off of zero. Thus, i cant be sure exactly how much my saw is off. If i even sneeze the stupid thing goes out of zero
I think i need a new gauge, a better one anyway, that rides in themitre slot.
I dont know, i really dont want to drop 100$ on a gauge but understand the need for precise instrumentation.
Any help would be appreciated and thank you in advance.
16 replies so far
View HokieKen's profile
HokieKen
15157 posts in 2020 days
#1 posted 12-10-2018 09:12 PM
I have never used a HF indicator but I know lots of people do. Is it the dial indicator itself that is the issue or is it the miter gauge bar having slop in the slot that is the issue?
If its the indicator itself, I can give you several good brands you can look for on ebay if you want a really good but older indicator. Or, newer brands like iGaging make “good enough” precision instruments at affordable prices. But indicators are a whole can of worms we’ll open only if necessary ;-)
If it’s a matter of slop in the miter gauge there is a cheaper and better solution. Get a good quality, adjustable miter bar so you can adjust any and all slop out of it. Then make a block that you can FIRMLY & RIGIDLY attach your indicator to and bolt the block to the miter bar.
I have a setup like this that I used to align my table saw and it worked wonderfully. Welcome to LJs!
-- Kenny, SW VA, Go Hokies!!!
Alexbringsthewood
#2 posted 12-10-2018 09:49 PM
I believe it may be slop, i tried keeping it “pushed” right the whole time.
Would you recommend digital or older type indicator?
HokieKen
#3 posted 12-10-2018 09:52 PM
I personally prefer a dial over digital but that’s just personal preference. I’d be more concerned with the quality of the manufacturer.
Alexbringsthewood
#4 posted 12-10-2018 10:03 PM
So what would recommend for a new tool? A-line, master gauge or woodpeckers. Those are the three i can find that look “quality”
View knotscott's profile
knotscott
8386 posts in 4257 days
#5 posted 12-10-2018 10:16 PM
I own a dial indicator, but have also had success using very low tech devices like a combination square or a brass screw on a stick. It’s not hard to get within a couple of thousandths with any of these devices….with wood working, that’s really as close as it needs to be.
Alexbringsthewood
#6 posted 12-11-2018 03:56 AM
So i think i may have gotten it.
I was able to make a temporary jig on my mitre gauge.
Pic 1: starting point at 0 (front)
Pic 2: 6/1000th of an inch off (back)
Pic 3: returned to 0 (not 100% but damn close)
Is that what you see?
View MikeDildayNoSpam's profile
MikeDildayNoSpam
285 posts in 1341 days
#7 posted 12-11-2018 01:03 PM
View Dustin's profile
Dustin
707 posts in 1622 days
#8 posted 12-11-2018 01:24 PM
Just get the Woodpeckers Table Saw Gauge and be done with it.
https://www.woodcraft.com/products/woodpeckers-saw-gauge?gclid=Cj0KCQiA3b3gBRDAARIsAL6D-N-aZiGo8yFVX8G6UCgmCkpfEIJuJResmwpqIsmSHKbNV7cUVEZflNsaAmy_EALw_wcB
- MikeDilday
Mike, I think there’s a lot of folks (myself included) who would rather spend that $90 elsewhere, particularly when this is a seldom used tool where, as KnottScott mentioned, low tech approaches work.
Before I got a dial indicator, I used the combination square method he mentioned. When I finally got a dial indicator, the setting using the combination square was only 0.002” off, which is just fine.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
HokieKen
#9 posted 12-11-2018 01:50 PM
Looking good Alex. Make sure the back of the blade is further from your fence than the front and not visa-versa. Otherwise the back of the blade will pinch your work and burn the wood at best or cause a kickback at worst.
Alexbringsthewood
#10 posted 12-11-2018 02:01 PM
Just to double check, if the dial goes backwards, like it does in the pics, the back of the blade is further “in” than the front, which is likely why i have burning on the wood and crooked cuts?
HokieKen
#11 posted 12-11-2018 02:10 PM
Yes. Assuming your fence is on the right side of the blade, the back of the blade is closer to the fence. In order to get good, clean, repeatable results (and do so safely) you’ll want to adjust so the back of the blade is further from the fence.
Be aware, this assumes your fence is perfectly parallel to the miter slot. You should check that with the indicator as well.
Alexbringsthewood
#12 posted 12-11-2018 02:37 PM
Thank you for all the advice. I just purchased a woodpeckers saw gauge, it was on sale and i think this is something i really need.
On the saw, 6/1000th is pretty far out of alignment right?
HokieKen
#13 posted 12-11-2018 02:46 PM
- Alexbringsthewood
Not really. As long as the back of the blade isn’t pinching the wood, you’re in good shape. When I aligned my saw after purchasing it, I aligned the blade to within .010” and called it good. You can get it closer if you want to take the time to do so but I’d be perfectly happy with .006”.
View Robert's profile
Robert
4048 posts in 2363 days
#14 posted 12-11-2018 04:17 PM
Alex you can also use something like what knotscott shows + feeler gauges. It will get you plenty close enough.
You really want to get the miter slot/blade as parallel as possible. IMO you should shoot for dead on or at least within .001-.002”. Its a setting that once you get it, its done for life (usually) so its worth the effort.
Once you get that, then adjust your fence so the fence-to-blade is .003 more at the rear of the blade. Do this with the blade fully raised and use the same tooth for the measurements.
View ChefHDAN's profile
ChefHDAN
1772 posts in 3731 days
#15 posted 12-11-2018 05:18 PM
- Alexbringsthewood
I set up my saw for the first time with the combo square and a stick with a brass screw in the end as shown above. I got an HF dial indicator and did a little better with that, but when I stumbled on the WP saw gauge on sale for $50 I grabbed one and absolutely love it for the speed and accuracy, and no fussing about, yes there are other was to get the job done but time is money too.
