Morse Carbide Tipped Quiksilver Blade problems
Forum topic by aterrell posted 12-10-2018 02:57 PM 542 views 0 times favorited 11 replies Add to Favorites Watch
View aterrell's profile
aterrell
9 posts in 1267 days
12-10-2018 02:57 PM
I recently bought a Morse Carbide tipped blade. It says quiksilver on the box. The blade is brand new out of the box and it burns the wood when cutting. It did this the first time I put the blade on the saw.
Has anyone had a problem with this? And yes it is on correctly.
11 replies so far
View pottz's profile
pottz
20727 posts in 2232 days
#1 posted 12-10-2018 11:06 PM
i assume you mean a table saw,and by correctly youve checked that the blade is aligned parallel to the fence? this is the biggest problem when you get burning.
View AlaskaGuy's profile
AlaskaGuy
6748 posts in 3557 days
#2 posted 12-11-2018 12:35 AM
- pottz
Hard to say. My search came up with this.
http://www.mkmorse.com/carbidetipped
AlaskaGuy
#3 posted 12-11-2018 12:36 AM
I think he mean band saw.
http://www.mkmorse.com/quiksilverHEF
AlaskaGuy
#4 posted 12-11-2018 12:37 AM
BTW never hard of this brand.
pottz
#5 posted 12-11-2018 12:44 AM
yeah i saw that,but burning from a bandsaw? they do make table saw blades and sawzall blades too so we’ll have to wait for a little better explanation.hard to help someone with vague info.
View AHuxley's profile
AHuxley
874 posts in 4569 days
#6 posted 12-11-2018 12:45 AM
What is the blade TPI?
aterrell
#7 posted 12-11-2018 12:49 AM
Sorry Yes it is a bandsaw. I thought I put that in the post but I didn’t. It is a 3 tpi. It smokes the wood with a very strong smell and can even see the smoke in the air. I have had this from a dull regular blade but a quick resharpen and it is back to cutting fine. The odd thing is that if I push the wood through faster it doesn’t burn. But the blade doesn’t leave a nice smooth finish that I expected. I got the blade from a wood working store.
View RobHannon's profile
RobHannon
347 posts in 1778 days
#8 posted 12-11-2018 02:25 PM
Do the teeth have any set to them? Any chance the wood you are cutting is trying to pinch closed after the cut?
If you are resawing it will have a sweet spot as far as feed rate.
View MrRon's profile
MrRon
6188 posts in 4491 days
#9 posted 12-12-2018 01:17 AM
Morse is more known for their metal cutting blades which don’t have the amount of set that wood cutting blades have. Are you sure the blade you got was for wood and not metal?
pottz
#10 posted 12-12-2018 01:51 AM
he said its only 3tpi though.
AHuxley
#11 posted 12-12-2018 01:57 AM
- RobHannon
Carbide tipped bandsaw blades don’t have set per se. They are not bent out like a carbon or bi-metal blade, the teeth are ground like a table saw blade.
To the OP which model blade do you have? Have you tried cutting different wood?
