Adding mosers fresco colors to Zinsser seal coat?
Forum topic by Pizzadave posted 12-10-2018 04:29 AM 785 views 0 times favorited 6 replies Add to Favorites Watch
View Pizzadave's profile
Pizzadave
125 posts in 966 days
12-10-2018 04:29 AM
Topic tags/keywords: sealcoat frescocolors birchplywood birchhardwood
Hi there. I am experimenting with toners in dewaxed shellac. Zinsser.
I have purchased some mosers fresco colors and I was wondering if that is ok to mix with the seal coat. The directions have me scratching my head. I did experiment a bit with it and the color that I index up with is awesome looking. I am staining birch plywood and black birch hardwood. 7 samples of.
1. Gel stain
2. Seal coat and then gel stain
3-7 were different shades.
Like I mentioned I have found a look I really like with mixing the dye and the seal coat with measured amounts. My question pertains to long term. Will I run into any issues with mixing the two? Much appreciated. DP
-- Dave, NY, It works-It really does!
View Rich's profile
Rich
5989 posts in 1474 days
#1 posted 12-10-2018 05:52 AM
I haven’t used the fresco colors, but when the first thing that pops up on a search is:
“J. E. MOSER’S ® Fresco Colors are super refined, pure dry pigments designed for coloring, mixing and tinting most paint, enamel, epoxy, fillers, shellac, stains, lacquer, varnish or other liquids: Very useful for touch up work when quick color matching or changes are required.”
I’d say yeah, mixing with Seal Coat is fine. You’re doing sample boards, which is a smart move, so I’d say don’t worry so much. You’re doing great.
Pizzadave
#2 posted 12-10-2018 11:05 AM
I really appreciate your response. Mixing dyes is new to me but I must say I really like the idea.
View OSU55's profile
OSU55
2658 posts in 2874 days
#3 posted 12-10-2018 01:12 PM
Mfr states they mix with shellac so should not be an issue. I use Transtint which are already dissolved and very easy to add drop by drop. I think the Moser dyes are rebranded Transfast powdered dyes.
Pizzadave
#4 posted 12-10-2018 01:44 PM
I will try the transit next. Can you use it with seal coat? Thanks for responding
OSU55
#5 posted 12-10-2018 03:29 PM
Yes Transtint will mix with alcohol and water based products as well as solvent lacquer. Will not mix with oil based products. I use wd lockwood oil based powders dissolved in naptha for those.
Pizzadave
#6 posted 12-10-2018 05:26 PM
Cool. Thank you!
