Wiring PM075 Motor
Forum topic by Fuzzybearz posted 12-09-2018 02:53 AM 333 views 0 times favorited 5 replies Add to Favorites Watch
View Fuzzybearz's profile
Fuzzybearz
104 posts in 672 days
12-09-2018 02:53 AM
Alright. I got 2 issues. I disassembled the motor because I was going to bring the housing inside, but instead decided to just bring in the switch. So, now that it’s reassembled here are my problems.
1) Did I do the ground correctly?
2) I only used 4 screws, where do the others go?
1)
Picture A and Picture B – Original before disassembly to orient
Picture C and Picture D – What do I do with the Yellow Box Ground wire? When I went to reassemble, the green wire was attached to nothing. I know the Red Wire from the Power Cord is going to get screwed against the black back plate, but does the Green one also get screwed to the backplate front and back?
Picture E and F – What I envision as correct. Loose green wire is screwed in front with the power ground, then on the back it is screwed in. Not sure how this ground works but it seems like it should be correct.
2) I used 4 screws, the ones for the holes shown in blue in pictures E and F, but there are 2 more holes that are colored white in that picture and I have like 4 screws remaining. Not sure where they go, any ideas.?
5 replies so far
View ArtMann's profile
ArtMann
1462 posts in 1419 days
#1 posted 12-09-2018 03:01 PM
Green wires always indicate chassis ground. I would not attach any other color wire to the back plate.
Fuzzybearz
#2 posted 12-09-2018 06:56 PM
So green wire to the backplate is ok. Just not any other color right?
- ArtMann
View TheFridge's profile
TheFridge
10859 posts in 2089 days
#3 posted 12-09-2018 08:09 PM
Ditto
View Jim Deatsch's profile
Jim Deatsch
18 posts in 456 days
#4 posted 12-09-2018 09:08 PM
Fuzzy,
“Green is ground, the world around.” Unless it’s not.
-- It's 5 o'clock somewhere. Scott Kalitta
Fuzzybearz
#5 posted 12-09-2018 09:11 PM
So, the reason I have this question is not because I don’t know what the green wire is, it’s because I have no idea how it is grounding.
Is it grounding the motor to the ground wire in the electrical power cord and using that ground? Because my motor doesnt have a ground to the ground
I probably didnt pose my question accurately :)
