kreg miter gauge and sawstop -- attention to details
Forum topic by trsnider posted 12-09-2018 12:06 AM 1218 views 0 times favorited 17 replies Add to Favorites Watch
View trsnider's profile
trsnider
169 posts in 2621 days
12-09-2018 12:06 AM
Topic tags/keywords: sawstop kreg problem miter gauge
Well %@#$!!! The Kreg miter gauge and Sawstop don’t play well together. The Sawstop trips if the gauge runs into it. It’s an expensive mistake to make (don’t ask how I know), and it always happens on a Saturday after the store is closed. So another wait until Monday. Think I’ll make that sled tomorrow, assuming I have the sheet goods (probably don’t). Big sigh. I’m sure that no one else has done this. I’m sure that Kreg will help with the cost of a new cartridge. HAHAHAHA.
Thanks for letting me vent.
17 replies so far
View Rayne's profile
Rayne
1300 posts in 2150 days
#1 posted 12-09-2018 12:33 AM
Just an FYI…any metal hitting the blade will most likely trigger the brake system, so it’s not only the Kreg Miter system, in case you have any other system made out of metal or any lumber that could have nails, staples, or whatnot in them. I watched so many videos before getting the SS that I’m paranoid in checking for rogue staples or nails in my lumber before running them through just because of the potential expensive mistake that would ensue. Good luck in your future work (and yes, the table saw sled will be one of those “why didn’t I build this first” kind of project. I waited on my first table saw and regretted waiting; built one relatively quickly when I got my SS and it is amazing to use).
View EugdOT's profile
EugdOT
305 posts in 1166 days
#2 posted 12-09-2018 01:16 AM
Putting it in bypass helps a lot to avoid tripping it when in doubt bypass it. Then cut anything you want just don’t forget that the safety is off
View MikeDilday's profile
MikeDilday
284 posts in 1070 days
#3 posted 12-09-2018 03:49 AM
- EugdOT
Putting it in bypass isn’t good for the Kreg miter or your hand if you have an accident. I only use bypass when I am cutting questionable wood like tree branches.
-- Michael Dilday, Suffolk, Va.
MikeDilday
#4 posted 12-09-2018 03:50 AM
Actually I’ve done that very thing twice. Hmmm. I also tripped it with a tree branch making a cupcake stand for my daughters wedding. Three times for me. Now I keep a spare brake and blade on hand. I think I will start being a little more careful and make sure I am clear of the blade when I make angle cuts.
trsnider
#5 posted 12-09-2018 02:36 PM
The bypass idea is great, considering that I had forgot about that capability.
MikeDilday
#6 posted 12-09-2018 02:46 PM
- trsnider
If you bypass it what happens if your miter gauge hits the blade? Or worse your hand hits the blade? The miter gauge costs more than the brake, at least mine does.
View johnstoneb's profile
johnstoneb
3131 posts in 2783 days
#7 posted 12-09-2018 02:59 PM
Aluminum taper jigs don’t play well with a sawstop either.
-- Bruce, Boise, ID
View Manitario's profile
Manitario
2798 posts in 3494 days
#8 posted 12-09-2018 03:51 PM
Yep, Incra gauges don’t seem to do well either when they are run into the blade. Don’t ask me how I know…
View pontic's profile
pontic
722 posts in 1219 days
#9 posted 12-09-2018 04:11 PM
saw stop should try to develop some type of reactive ground on the system one that is keyed to your bodies capacitive resistance. This could be done by pirating the software and circuitry from the Laser surgery systems.There are a lot of old ones,and parts lying around in the hospitals and used medical supply offices. Those systems have a tunable safety sensor based on the doctors body resistance/capacitancethat turns itoff when his body or hands touch the fire port of the laser. They could make something like that so it would only work when the operator touched it.
-- Illigitimii non carburundum sum
View Aj2's profile
Aj2
2656 posts in 2409 days
#10 posted 12-09-2018 06:49 PM
I hope you guys don’t think the Aluminum fence is a sacrificial fence. I had two on my unisaw and thought they were great. I do know when the blade gets tilted the fence needs to slide back.
-- Aj
View TheFridge's profile
TheFridge
10859 posts in 2097 days
#11 posted 12-09-2018 08:17 PM
Ditto
MikeDilday
#12 posted 12-09-2018 10:56 PM
Everybody keeps talking like they don’t want the saw brake to activate when it hits a steel or aluminum fence. I don’t understand why you would want the blade to keep spinning at over 3,000 RPM when it hits metal. You definitely don’t want to destroy an expensive fence and you don’t want pieces of metal flying around the room either. The solution is try not to hit metal but if you do be thankful that you at least saved your fence and didn’t get hurt. Last time I did it I had to spend $70 for the brake but I saved a $140 miter gauge. Either way the blade is destroyed.
View edapp's profile
edapp
331 posts in 2040 days
#13 posted 12-10-2018 01:02 PM
Why are you running the aluminum fence into the blade anyway? Scoot the aluminum away from the blade and use a sacrificial board when necessary…. True for any type of saw.
I have my incra miter setup far enough from the blade to be able to run a sharkguard overhead DC and they all play very well together.
View therealSteveN's profile
therealSteveN
4670 posts in 1185 days
#14 posted 12-10-2018 02:49 PM
I don’t have a weeney cutter so I’m not sure what is being said here? Is this just the presence of metal in the miter slot, or are you attempting to saw up a piece of metal?
If it’s the presence of metal, what is the stock miter gauge made of?
If it’s the later, I would think a moment with a dry (non powered) run through may be in order maybe??
-- Think safe, be safe
View Monty151's profile
Monty151
85 posts in 452 days
#15 posted 12-10-2018 03:32 PM
Weeney Cutter LMAO
