Secret Recipe v General Finishes and Danish v BLO
Forum topic by Noel posted 12-08-2018 02:07 PM 564 views 0 times favorited 9 replies Add to Favorites Watch
View Noel's profile
Noel
86 posts in 410 days
12-08-2018 02:07 PM
I know the topic of tabletop finishes has been explored ad nauseum here and I have gone through past posts, but I can’t seem to find a definitive answer on a couple of things (or maybe I’m just being indecisive!). I’m getting ready to apply finish to a walnut side table and I’m looking for as natural, yet as durable, a finish as possible. I do want protection from drinks, but I want minimal sheen. There seems to be a lot of support for the secret recipe (BLO, MS, Poly in equal parts) but would General Finishes Arm-R-Seal accomplish the same thing in less time? If I go with the secret recipe, any thoughts on Danish oil v BLO? Also, it was suggested that I could also apply BLO followed by GF, but I’m concerned about drying time with that approach. ??
Under either approach, my thought is to knock down any sheen by rubbing out final coat with carnauba or similar with 0000.
Sorry about the barrage of questions!
-- Just make the cut
9 replies so far
View OSU55's profile
OSU55
2498 posts in 2593 days
#1 posted 12-08-2018 02:38 PM
Reading This should help you make a decision. No secret recipe or blo or danish oil needed – just makes for a softer less durable finish (interior not exterior). Most any brand poly will work – I use minwax (ars is just another poly). Adjust # of coats and viscosity depending on application method and desired film thickness. Incorrect application – Too much gloss and too much film thickness – is where poly gets a bad rap for looking like plastic. For min sheen use satin and rub with 0000 – let it cure, not just dry. Unless you want a thick film use satin for all coats, it wont be any more cloudy looking. Advantage of satin is negative grain or defects wont shine like gloss – another reason for the “plastic look” bad rep.
View 9x9's profile
9x9
100 posts in 1843 days
#2 posted 12-08-2018 03:27 PM
^ ^ ^ Like what he says ^ ^ ^ ^
-- Youngsville, LA
View Noel's profile
Noel
#3 posted 12-08-2018 03:27 PM
Hallelujah! Decision made and article favorited. This kind of simple solution is exactly what I needed. Thanks OSU!
View bilyo's profile
bilyo
959 posts in 1706 days
#4 posted 12-08-2018 03:51 PM
- OSU55
I agree with OSU55. If I may elaborate a bit: Don’t be afraid to thin the poly. 50% is not too much. Then apply in very thin coats. A blue paper shop towel folded into several thicknesses works well. Think like you are wiping a counter top with a well wrung out damp towel. You want to just leave it damp, not flooded. After you have the finish built up to your liking, I prefer finishing up with 600 grit wet/dry using soapy water to lubricate. Silky smooth.
View Noel's profile
Noel
#5 posted 12-08-2018 05:26 PM
Testing thin coat of 50% poly cut with mineral spirits now. Either wood is thirsty or this will require a lot of coats. No dramatic pop after 1st coat. Just for Ss and Gs, also testing arm-r-seal and straight BLO. BLO has best pop after 1st coat.
OSU55
#6 posted 12-08-2018 05:45 PM
I just noticed I left this part out of the blog – now updated – for the 1st 2 coats, keep the surface wet for 5–10 min, then wipe off the poly, not completely dry, but just a “damp” film.
Noel what is your definition of “pop”?
View Noel's profile
Noel
#7 posted 12-08-2018 07:34 PM
Sorry, I come from the printing industry where by pop, we mean rich, bright, vibrant color. I’d like the woods natural color to be brought out without muddying the grain or figure. Does that make any sense?
View CaptainKlutz's profile (online now)
CaptainKlutz
2213 posts in 2097 days
#8 posted 12-08-2018 08:50 PM
Walnut pop?
Most my walnut is ugly grey/brown color derived from kiln drying with steam to balance color between sap & heartwood for an increase yield. I use dye 99+% of time on kiln dried walnut. Grain always pops with dye. Prefer to use highly diluted Transtint Mission Brown alone .vs. adding it to the 1st poly seal coat as OSU55 blog suggests. I use acetone/alcohol blend for dye stain solvent, and I can adjust color rubbing out with clean cloth wet with solvent blend.
For air dried walnut, don not need any color. I have had best grain pop rubbing on BLO, before using Arm-R-Seal poly. If you don’t flood coat the BLO, and you dilute it 50% with MS, it dries in reasonable time (<12-14 hours here in AZ).
YMMV
View Richard's profile
Richard
11309 posts in 3636 days
#9 posted 12-09-2018 01:13 AM
- OSU55
I agree with OSU55. If I may elaborate a bit: Don t be afraid to thin the poly. 50% is not too much. Then apply in very thin coats. A blue paper shop towel folded into several thicknesses works well. Think like you are wiping a counter top with a well wrung out damp towel. You want to just leave it damp, not flooded. After you have the finish built up to your liking, I prefer finishing up with 600 grit wet/dry using soapy water to lubricate. Silky smooth.
- bilyo
Good Method all around.
Rick S.
-- Richard (Ontario, CANADA)
