New Treadle Lathe
« back to Woodturning forum
Forum topic by ElroyD posted 12-08-2018 12:53 AM 967 views 0 times favorited 9 replies Add to Favorites Watch
View ElroyD's profile
ElroyD
134 posts in 1195 days
12-08-2018 12:53 AM
Topic tags/keywords: treadle lathe treadle lathe
A couple of weeks ago, a guy on Facebook posted a FREE treadle lathe on Facebook. A friend of mine spotted it and sent me the link. Within a couple of days, said lathe was packed into our minivan and safely transported home. Apparently it was built by a woodworker, for another woodworker who passed away. It was then passed along to the young guy who gave it to me. His only stipulation was that if I should ever decide to get rid of it, that I give it away freely as well.
It’s very sturdily built, with a 40 pound weight as the center of the flywheel. Headstock, tailstock, centers, bearings, and all were included. The only thing missing is a link between the treadle and the wheel.
The original builder had added a set of bicycle gears to the wheel axle to act as a clutch gear. This allows the wheel to turn forward, then coast if the gear should turn backwards. I think the theory is that it would eliminate some treadling to save some energy.
At this point, I have everything working, but still no link between the treadle and the gear. Any suggestions on the best approach to create this link?
-- Elroy
9 replies so far
View Oldtool's profile
Oldtool
2804 posts in 2798 days
#1 posted 12-08-2018 01:00 PM
Looking at the pictures, my “guess” is that there needs to be a ridged link between the treadle and the outer most gear ( I know – duh!”) that swivels on both ends. This then pulls the gear forward to spin the lathe, and also allows the gear to be pushed back to it’s original position to start another pull on the lathe while it spins.
I think you will need to drill the gear to accept a swivel pin, same for the treadle, maybe use a bolt, and for a rod use something with a loop on each end. I think that a piece of coat hanger wire could be fashoned to do the job.
To check my speculations, pull the gear forward and push it back as if connected to the treadle, see if I am even close to correct.
Good luck.
PS, nice find, this will be fun to use. Post your first project from it.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
ElroyD
#2 posted 12-08-2018 07:02 PM
Looking at the pictures, my “guess” is that there needs to be a ridged link between the treadle and the outer most gear ( I know – duh!”) that swivels on both ends. This then pulls the gear forward to spin the lathe, and also allows the gear to be pushed back to it s original position to start another pull on the lathe while it spins.
- Oldtool
https://video-lga3-1.xx.fbcdn.net/v/t42.9040-2/4742476736398972419667623795158201925632n.mp4?nccat=102&efg=eyJybHIiOjY0NCwicmxhIjo1MTIsInZlbmNvZGVfdGFnIjoic3ZlX3NkIn0%3D&rl=644&vabr=358&nc_ht=video-lga3-1.xx&oh=d72133cb9781a434931c7843876d9290&oe=5C0C44B1
Yep. That’s exactly how it works. A few days ago I tightened the nut in the center of the gears, and the gear started working as expected. I’ll play with it some more when the weather warms up (0 degrees this morning, and it’s only December).
-- Elroy
View duckmilk's profile
duckmilk
3938 posts in 1932 days
#3 posted 12-08-2018 09:59 PM
Nice idea for the gearing Elroy. Maybe go to a bicycle shop and show them the pictures and video and see if they have any suggestions?
-- "Duck and Bob would be out doin some farming with funny hats on." chrisstef
View Mosquito's profile
Mosquito
10002 posts in 2899 days
#4 posted 12-08-2018 11:29 PM
can’t see the video anymore, it seems.
Another possible solution is a chain attached to the treadle peddle, around one of the gears, and then fastened to a spring mechanism (torsion spring, or extension spring) on the treadle somewhere
It’s how many of the Barnes treadle table saws work
https://www.youtube.com/watch?v=giCJUCbAjOQ
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
ElroyD
#5 posted 12-08-2018 11:49 PM
Mos, you may have hit on the original design that was intended! The treadle is wide enough to attach a chain to the front and back, and it already has a torsion spring attached below it. I’ve got some old bicycles in our barn that I can scavenge chains from. I’ll give that a try. Thanks!
-- Elroy
Mosquito
#6 posted 12-09-2018 02:05 AM
I would be interested in seeing it, if it works out :) (or even if it doesn’t, I’m just interested lol)
ElroyD
#7 posted 12-11-2018 07:31 PM
It worked! I cut a chain off from an old bike in our barn, and tacked it in place on both sides of the treadle to test it. Now that I know it works, I’ll fix a more permanent solution.
https://youtu.be/_idm75IVUS4
-- Elroy
Mosquito
#8 posted 12-11-2018 07:56 PM
Awesome! Thanks for the update :-)
View Dave Polaschek's profile
Dave Polaschek
4456 posts in 1189 days
#9 posted 12-12-2018 01:23 AM
Good job, Elroy! Sweet lathe!
-- Dave - Santa Fe
