Repairing warped barn door
Forum topic by vgV posted 12-04-2018 05:34 PM 1852 views 0 times favorited 10 replies Add to Favorites Watch
View vgV's profile
vgV
4 posts in 417 days
12-04-2018 05:34 PM
Topic tags/keywords: advice question
Hello,
I’m a newbie. This is my first attempt to build something please don’t be harsh.
My daughter ask me to build her a custom barn door because based on her size standard door was too expensive.
I had this some loose wood in my garage for almost 3 month I assumed it wood be dry enough for the project.
after about 8 moths the door warped on the left bottom corner.
Is there anything i can do to fix it?
10 replies so far
View Aj2's profile
Aj2
2651 posts in 2406 days
#1 posted 12-04-2018 06:17 PM
No that’s beyond repair.
Build a new one buy wood from a lumber yard that’s kiln dried. Store and sticker the wood to lay flat. Buy extra and use only the best ones to remake the door.
Ok
-- Aj
View JCamp's profile
JCamp
1040 posts in 1159 days
#2 posted 12-04-2018 06:21 PM
I don’t know what all the hardware if called but they make stuff to straighten those doors out. It’s basically a couple screws with eye holes and threaded piece that u can tighten to bring the door back down. I’ve seen them on Amish buildings but never had to use them. Hopefully someone here will know the technical words for it.
Btw I think the door looks great.
-- Whatsoever thy hand findeth to do, do it with all thy might
View Scap's profile
Scap
99 posts in 535 days
#3 posted 12-04-2018 06:23 PM
- JCamp
Turnbuckle?
View vgV's profile
vgV
4 posts in 417 days
#4 posted 12-04-2018 06:29 PM
I was thinking about using Turnbuckle https://www.youtube.com/watch?v=s9avOb6EH58 https://www.youtube.com/watch?v=Db5TiyyXeIY
but wasn’t sure it it would let me straighten this door because it big.
I also found this https://www.youtube.com/watch?v=5eVnfPkdLpc but not sure what is the name of this product
View John Smith's profile
John Smith
2135 posts in 771 days
#5 posted 12-04-2018 07:12 PM
there was a very similar post identical to this one a few months ago. (use the search feature).
basically using the turnbuckles and cables to pull it back into shape.
[I think the author of that post wound up making a new door].
I agree with a higher quality wood and avoid extreme acclimation issues.
-- I am a painter. That's what I do. I paint things --
View Aj2's profile
Aj2
#6 posted 12-04-2018 07:21 PM
Are the panel’s floating or are they glued together. If they dont have room to move in a groove top and bottom your construction method needs improvement.
-- Aj
View vgV's profile
vgV
4 posts in 417 days
#7 posted 12-04-2018 07:29 PM
The panel’s are glued together and frame brace is nailed in(finishing nails). I used Biscuits on the sides and mortise and tenon joint one the ends
Smitty_Cabinetshop
16341 posts in 3227 days
#8 posted 12-04-2018 07:35 PM
Sorry, but if it is going to be spelled panel’s then at least be consistent and say nail’s and biscuit’s and side’s and end’s.
View Aj2's profile
Aj2
#9 posted 12-04-2018 08:43 PM
I think your door warped because of your construction. It’s very common for new woodworkers to build their first few projects too stiff or shiny.
Don’t feel bad everyone does it. Just make a new one with proper construction
-- Aj
View MikeDilday's profile
MikeDilday
284 posts in 1067 days
#10 posted 12-05-2018 12:00 AM
Take a cable & turnbuckle and block in the middle of the door to bend it slightly beyond straight and check it daily. It will straighten back out.
-- Michael Dilday, Suffolk, Va.
