Sliding compount miter saw... advice?
Forum topic by MalcolmLaurel posted 12-04-2018 02:06 AM 1080 views 0 times favorited 11 replies Add to Favorites Watch
View MalcolmLaurel's profile
MalcolmLaurel
301 posts in 2231 days
12-04-2018 02:06 AM
Topic tags/keywords: miter saw
My son in law has a sliding compound miter saw on his Christmas wish list. I’ve done a lot of woodworking, but never owned a miter saw, I use my RAS for all that kind of stuff, so I don’t know that much about them. Probably a 10”, and I’m looking to spend $200-250. I see a Kobalt (older model) was reviewed favorably here some years ago, Lowes sells a newer model for $199. The Wen 70730 is $195 from several retailers and has mostly good reviews, except for a few comments about an oversize shaft that won’t take standard blades with a 5/8” hole. Not familiar with Wen, though. And the usual offerings from Dewalt, Hitachi, etc. Any comments or suggestions?
-- Malcolm Laurel - http://MalcolmLaurel.com
11 replies so far
View josephf's profile
josephf
217 posts in 2705 days
#1 posted 12-04-2018 02:17 AM
what is he going to use it for .
MalcolmLaurel
#2 posted 12-04-2018 02:23 AM
General use, I think, dimensional lumber and moldings, shelves, etc. They’re looking at houses, probably a fixer upper, so the kinds of things that would need.
View BoilerUp21's profile
BoilerUp21
149 posts in 1375 days
#3 posted 12-04-2018 02:31 AM
View mrg's profile
mrg
860 posts in 3608 days
#4 posted 12-04-2018 03:42 AM
The Hitachi is a great saw. I love mine. Check out the review I posted.
-- mrg
View GrantA's profile
GrantA
2133 posts in 2016 days
#5 posted 12-04-2018 03:50 AM
I think this is the same shopmaster but a little cheaper @$149 til the 5th
https://m.lowes.com/pd/DELTA-SM-10-in-15-0-Amp-Single-Bevel-Sliding-Laser-Compound-Miter-Saw/1000668563
Not sure dollar for dollar you’ll beat that deal!
View MikeDilday's profile
MikeDilday
284 posts in 1067 days
#6 posted 12-04-2018 04:46 AM
Dewalt is the one I would get. There is a great review online that ranks Dewalt at the top.
-- Michael Dilday, Suffolk, Va.
View SMP's profile
SMP
1598 posts in 514 days
#7 posted 12-04-2018 06:04 AM
If you aren’t sure he is going to stick with it or maybe see rare use, the Harbor Freight ones actually get decent reviews for the price. Dirt cheap with coupon. With the money you save go get a GOOD quality blade and it wil cut better than many more expensive saws out of the box.
I have a 12” DeWalt sliding compound and i don’t have one complaint. If you think he will stick with it I’d go DeWalt.
View Underdog's profile
Underdog
1438 posts in 2644 days
#8 posted 12-04-2018 11:19 AM
- SMP
And what would you consider a good quality blade?
-- Jim, Georgia, USA
View knotscott's profile
knotscott
8364 posts in 3984 days
#9 posted 12-04-2018 12:07 PM
- SMP
- Underdog
Infinity, Forrest, Ridge Carbide, Tenryu, Amana Tool, Freud Industrial, CMT Industrial, Everlast, Freud Diablo, Irwin Marples, to name a few. If he ends up with a slider, be sure to get a blade that has a low to negative hook angle on the teeth.
runswithscissors
3081 posts in 2633 days
#10 posted 12-05-2018 05:39 AM
Negative hook angle shouldn’t be necessary on a miter saw, as you push the blade through the work, rather than pull it like you would on a RAS. But you do want lots of teeth for smooth crosscutting. 60 teeth at least.
Underdog
#11 posted 12-05-2018 11:08 AM
- knotscott
Negative hook angle shouldn t be necessary on a miter saw, as you push the blade through the work, rather than pull it like you would on a RAS. But you do want lots of teeth for smooth crosscutting. 60 teeth at least.
- runswithscissors
Actually, you should note that he said “if he ends up with a slider”. In that case, it’s just like a radial arm saw in which the the lower negative rake helps…
