Laguna Jointer Rest Switch
Forum topic by JSMorgan posted 12-04-2018 01:14 AM 506 views 0 times favorited 6 replies Add to Favorites Watch
View JSMorgan's profile
JSMorgan
48 posts in 1157 days
12-04-2018 01:14 AM
Topic tags/keywords: laguna jointer reset switch
I was using my Laguna 8” helica cutter head jointer. All of a sudden it stopped. I contacted Laguna and they said to look for a reset switch which may have popped. I either did not find it or it had not popped. Anyone know where it is located?
Thanks,
Jerry
View therealSteveN's profile
therealSteveN
6435 posts in 1454 days
#1 posted 12-04-2018 01:26 AM
Should be quite visible on the motor if you have one. Seeing as how they likely knew which model you had, I’d assume you do. Small red button, with a metallic surround.
-- Think safe, be safe
JSMorgan
#2 posted 12-04-2018 01:42 AM
TheReal: That’s sort of what I was looking for but did not see it. You say on the motor but there is a junction box that also leads to the main power switch mounted on the frame I was looking at. Laguna said it was in a “black box” which is what I was looking at. Also, I checked the motor and did not see anything either.
Thank you!
View fly2low's profile
fly2low
88 posts in 977 days
#3 posted 12-04-2018 09:39 AM
If it is new, you might want to take the cover off of the switches and check the wiring. When new, mine worked fine for a month or so, then suddenly stopped. Took the cover off, two of the wires had fallen off the switch, and two more were loose. I talked to CS about this.
Works great otherwise
-- Rich Gig Harbor, WA
View DRas's profile
DRas
1 post in 657 days
#4 posted 01-05-2019 05:14 AM
JSMorgan
Did you find your answer? My motor would not turn on. I called Laguna. The jointer is brand new. They told me in the black box is a blue button, and they call this the reset button. No luck for me. But, I did hold in the reddish button that is very close to the blue button. The motor started, but, would turn off when I let go of the reddish button.
Was good to know that it would turn on. My guess is the blue button needs to be pulled out.
Let us know if you figured it out.
DR
View AlaskaGuy's profile
AlaskaGuy
6107 posts in 3189 days
#5 posted 01-05-2019 05:18 AM
Thanks,
Jerry
- JSMorgan
You would think good customer service would include telling you where it’s located. You don’t have a manual with a parts diagram?
fly2low
#6 posted 01-05-2019 07:50 AM
When I talked to CS about my wires not being fastened like they should have been, I also shared my opinion of their manual. Subpar would be a compliment to that thing
