Grizzly 4 Jaw Wood Turning Chuck
« back to Woodturning forum
Forum topic by Jim Jakosh posted 12-03-2018 10:55 PM 659 views 0 times favorited 17 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
23740 posts in 3707 days
12-03-2018 10:55 PM
Topic tags/keywords: tip
I have 2 Grizzly H6265 Wood Lathe Chucks and I talked the high school into buying a couple. Well we have only one now and it was almost scrapped, too. The first one had a jaw come out and someone threw it away with the chips and a set of jaws costs as much as a new chuck. I found the second one today with a jaw out of it and the problem is that Grizzly uses a 9/32” long 1/8” roll pin as a keeper to keep them from backing out. After while that pin slides down into the hole which is about 7/8” deep and the jaws don’t hit a limiter and come right out.
I fixed that chuck today and both of mine with a stepped pin that goes from the back of the chuck to sticking out 1/8” so it cannot retract and provides a positive limit for the jaws.
This is what it comes with:
I drilled out the 1/8” hole about half way up to 3/16” and turned down a 3 /16 pin to 1/8” and stuck it up in the chuck so it just fit in the back.
Now there is a positive limiter in the chucks!!
17 replies so far
View lew's profile
lew
12931 posts in 4357 days
#1 posted 12-03-2018 11:31 PM
Nice retrofit on the pin. Too bad the other jaw was lost.
View Druid's profile
Druid
2161 posts in 3397 days
#2 posted 12-03-2018 11:34 PM
Great, simple solution Jim. I’m wondering how long it will be before Grizzly updates their design. They should be contacting you to reward you for such a useful design upgrade.
Have a great day.
-- John, British Columbia, Canada
View Joe Lyddon's profile
Joe Lyddon
10859 posts in 4654 days
#3 posted 12-04-2018 12:04 AM
Sounds like Equipment should NOT be allowed to be in the hands of young people that have NO CLUE of how to USE them… or Fix them… (??)
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php
Jim Jakosh
#4 posted 12-04-2018 12:11 AM
Hi John, I have just sent this forum note to Grizzly after talking to the CS rep. for about 20 minutes. I repaired 5 chucks now with the stepped pin and don’t worry about the jaws coming out again on them. I wish they would send the school and new chuck at the least! In 2016 the chuck was $117 in my old catalog…it is now $174.
Cheers, Jim
View Tooch's profile
Tooch
2012 posts in 2477 days
#5 posted 12-04-2018 01:55 AM
- Joe Lyddon
How else should they learn?
Nice save Jim. Grizzly normally has decent stuff, but I have had some issues in the past with the detail things like your issue here.
-- "Well, the world needs ditch-diggers too..." - Judge Smails
Joe Lyddon
#6 posted 12-04-2018 02:10 AM
- Joe Lyddon
Throwing stuff away?! After messing it up? ... NOT asking for Help? ... Instruct them…? LOL Yes?
View bigJohninvegas's profile
bigJohninvegas
722 posts in 2063 days
#7 posted 12-04-2018 02:21 AM
Hi Jim, I have a H6267, mine is the 1-1/4X8tpi version. I believe yours are the 1X8 adapter. I think that is the only difference in there chucks. Different numbers for the adapters. If you would like to replace the jaws you will find that the vicmarc vm100 jaws will work fine.
I keep a vicmarc pin Jaws mounted on mine most of the time.
http://lumberjocks.com/reviews/6778
-- John
Druid
#8 posted 12-04-2018 02:53 AM
I would expect Grizzly to send a couple of their upgraded chucks to you for “in the field” evaluation. Then you could also report your findings right here.
View doubleDD's profile
doubleDD
8958 posts in 2645 days
#9 posted 12-04-2018 03:39 AM
Nice stop pin Jim. I had the same problem on their smaller model #G8784? I don’t like changing the jaws all the time especially when you have a few projects going at the same time. Great job saving all those chucks. They should last forever.
Jim Jakosh
#10 posted 12-04-2018 01:09 PM
Hi Joe, you should see the lathe room after I have not been there for a few days. Tools are out all over mixed with wood chips .It is no wonder a jaw got thrown out. I am repairing stuff on the machines every week. Today I have to take the spindle out of a Jet lathe to replace a missing/broken snap ring
Hi Big John, do you get both pieces of the jaw with the Vicmarc set or just the top pieces? If it was just the top piece that was missing, I could have turned one, but the bottom piece with the radiused grooves to fit the scroll plate was gone too.
Hi John. It would be nice if they sent us a new chuck!, but it was negligence on our part that it got discarded.
Cheers, Jim
Joe Lyddon
#11 posted 12-04-2018 03:50 PM
Jim,
Can you make some rules to CLEAN UP after use and BEFORE leaving the room? :)
Joe
View Grumpymike's profile
Grumpymike
2439 posts in 2917 days
#12 posted 12-04-2018 03:58 PM
Hi Jim,
I hope that you will recall the visit you made to my shop, you made a comment about my Grizzly chuck.
Well, I am happy to say that I still use that chuck and after several years of use and as I learned how to turn, some abuse, my Grizzly chuck is still operating normally; so no complaints here.
In looking at your photos, I noticed that your chucks are very used.
Great save on the retaining pins, but what would one do if they don’t have a metal turning lathe?? So I called Grizz .. they do have some replacement parts available.
To bad that the chuck part was lost, but look at all the spare parts you have now to keep the other chucks in repair.
Keep them kids turnin’
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
Jim Jakosh
#13 posted 12-04-2018 06:01 PM
Hi Joe, I’m just a volunteer there and not the teacher…but the new teacher is much like that with a desk that is littered to almost beyond use as a desk! I make comments to him about cleaning up the place but it does not do much good.
Hi Mike, Glad to see you got to turning. I think the lathe is the most fun tool in the whole shop. When I get students on them, they seem to get real creative!! Grizzly had replacement jaws with the lower scroll pieces but you have to buy a complete set, because they are made as a set, and it was as much as new chuck then.That old chuck was scrapped.
Cheers, Jim
Joe Lyddon
#14 posted 12-04-2018 06:38 PM
That’s too bad… Looks like you’re doing all you can…!!
View Festus56's profile
Festus56
3960 posts in 1829 days
#15 posted 12-04-2018 07:02 PM
That is interesting read and good save Jim. I was looking at Grizzly chucks for a long time and ended up buying Nova and have not had any problems. A quick look at mine and without looking at a parts diagram it appears they must be made a lot different.
-- Mark -- Really we're not crazy, just "Limited Editions" -- http://www.jmh-limited-editions.com/home.html --
