Top of Bookcase Cupped
Forum topic by JonnyRocket posted 12-03-2018 04:30 PM 468 views 0 times favorited 12 replies Add to Favorites Watch
View JonnyRocket's profile
JonnyRocket
9 posts in 664 days
12-03-2018 04:30 PM
Topic tags/keywords: bookcase cupped hand planing
I have a bookcase that I am working on, it’s already assembled and close to ready to be painted. The top of the case is slightly cupped, I’d say roughly 1/16-1/8” from the edges. What are my best options for getting this flattened? I have tried sanding and it’s just not feeling like I’m going to get the result I want. I have 0 functional hand planes in my shop, but I am not opposed to buying one to address this if that is the best tool for the job. Looking for ideas!
12 replies so far
View GrantA's profile
GrantA
2107 posts in 2010 days
#1 posted 12-03-2018 04:43 PM
Hard to say without seeing it. You could always add crown molding
JonnyRocket
9 posts in 664 days
#2 posted 12-03-2018 04:54 PM
It’s small/short. Only 26” tall and has doors on it. They will likely put stuff on top of it so that’s why I’m trying to fix the cupping.
GrantA
#3 posted 12-03-2018 05:03 PM
OK scratch that idea then! Solid wood I assume? What joinery? Short of a plane or belt sander I’m drawing a blank without seeing it
JonnyRocket
9 posts in 664 days
#4 posted 12-03-2018 05:11 PM
Sorry at work and don’t have a good photo of the top from the right angle.
It’s being painted black so went with simple stuff. Solid doug fir simple butt joint pocket hole.
I have tried my belt sander, it just wasn’t feeling difficult to get just the right section sanded down and not oversanding the low spots.
It’s cupped like …. this is bottom—> ) <—>s my best plane for the job? I am a complete NOVICE with hand planing.
GrantA
#5 posted 12-03-2018 05:14 PM
If you look at it from the side is it frowning or smiling?
JonnyRocket
9 posts in 664 days
#6 posted 12-03-2018 05:29 PM
Frowning.
GrantA
#7 posted 12-03-2018 05:33 PM
Have you tried tightening the pocket screws more? You’ve got a crown on the top, if you can’t tighten the screws more you might just want to leave it be
View sras's profile
sras
5284 posts in 3731 days
#8 posted 12-03-2018 05:46 PM
I don’t think you want to solve this by removing wood. The better option is to force it flat – is there room to add a couple boards to the underside? Run them front to back and use screws to pull the top flat. Slot the screw holes at front and back to allow for expansion/contraction of the top.
JonnyRocket
9 posts in 664 days
#9 posted 12-03-2018 05:59 PM
The butt joints are glued as well, so tightening screws I don’t think is going to do anything. I think the same goes for attaching anything underneath. This is one of those I’m trying to fix something after it’s already put together sort of things unfortunately. Thanks for all the replies!
GrantA
#10 posted 12-03-2018 06:21 PM
It may be glued but if it’s got a crown in the center then it isn’t tight there
View WoodenDreams's profile
WoodenDreams
881 posts in 513 days
#11 posted 12-03-2018 08:08 PM
You could cut the top off, then reprep or redo your top, and refasten. as a last alternative. A couple years ago, I had to redo a top because I didn’t like the final result. Was more work, but well worth redoing.
View SMP's profile
SMP
1564 posts in 508 days
#12 posted 12-03-2018 08:21 PM
You could cut the top off, then reprep or redo your top, and refasten. as a last alternative. A couple years ago, I had to redo a top because I didn t like the final result. Was more work, but well worth redoing.
- WoodenDreams
Agree, otherwise it become the “telltale furniture” and will bug you every time you walk by it.
