Help with router bit choice?
Forum topic by Woodrabbit posted 12-03-2018 02:46 PM 394 views 0 times favorited 6 replies Add to Favorites Watch
View Woodrabbit's profile
Woodrabbit
1 post in 420 days
12-03-2018 02:46 PM
Topic tags/keywords: router bed router profiles woodworking router bits question tip jig
Please look at the last image of this bed- the bottom rail. They have done something….like a chamfer bit on the top two sided with stops blocks for keeping the ends square to make the shadow line. I am trying to recreate it. Any ideas?
Thanks!!
https://www.etsy.com/listing/632265997/modern-maple-walnut-platform-bed-with?ref=related-2
View 000's profile
000
2859 posts in 1508 days
#1 posted 12-03-2018 03:26 PM
Is this what you are asking?
View Jeff's profile
Jeff
516 posts in 3804 days
#2 posted 12-03-2018 03:34 PM
It’s exactly what you describe, a chamfer bit stopped before going through the edge. Probably routed before cutting the tenons so there’s some wood to support the router. Relatively easy to do either free hand or on a router table.
View GR8HUNTER's profile (online now)
GR8HUNTER
6830 posts in 1322 days
#3 posted 12-03-2018 03:35 PM
J has the correct answer to your ? :<))
View SMP's profile (online now)
SMP
1603 posts in 515 days
#4 posted 12-03-2018 04:47 PM
It s exactly what you describe, a chamfer bit stopped before going through the edge. Probably routed before cutting the tenons so there s some wood to support the router. Relatively easy to do either free hand or on a router table.
- Jeff
Yep I do that on my router table, I just stick masking tape on the fence to mark where to start and end the cut. Test with a scrap piece.
View oldnovice's profile
oldnovice
7517 posts in 3977 days
#5 posted 12-03-2018 06:54 PM
You can also do a simliar treatment with a cove bit.
I use start/stop blocks on the fence to locate the length of the cove/chamfer.
117909 posts in 4186 days
#6 posted 12-03-2018 07:07 PM
Hello Welcome to Ljs
If you have a table saw why not do a bevel on it? I missed the part about leaving the ends square,
