Krenov jointer questions.
« back to Hand Tools forum
Forum topic by Mark Shultz posted 12-03-2018 02:18 PM 452 views 0 times favorited 3 replies Add to Favorites Watch
View Mark Shultz's profile
Mark Shultz
132 posts in 3000 days
12-03-2018 02:18 PM
I’ve been watching videos and reading about krenov planes, for my first attempt….
1) Mixed guidance on gluing vs not gluing the cross pin. What do you all recommd?
2) should the cross pin be flat bottomed? I’ve seen this a few times (clearly this one shouldn’t be glued).
3) does a chip breaker matter at all on a jointer? Mostly going to work edges vs flattening wide boards
4) do folks recommend the plane iron sticking up farther than the wedge, or vice versa?
Going with Hock 2” x 3.5” unless recommendations otherwise.
3 replies so far
View Derek Cohen's profile
Derek Cohen
482 posts in 4578 days
#1 posted 12-03-2018 02:39 PM
1. Do not glue the cross pin. It rotates. It is also not a round pin but a triangle. Look at plans – this is the heart-and-soul of the Krenov plane.
2. see above.
3. The chipbreaker matters all the time. I do not know whether Krenov used a chipbreaker. However, he sent me a smoother of his, and the chipbreaker was not set for a shaving. Nevertheless, on edges as well as faces, you want to avoid tearout.
4. The iron needs to be higher than the wedge since you need to hit it. The wedge projects in front of the iron, where it is accessible.
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
Mark Shultz
#2 posted 12-03-2018 03:40 PM
Thanks Derek. And nice website!.
Thanks for the comments. That’s why i was asking here – i see plans and videos of folks glueing the pin. FWW shows rounded, but one flat side, no glue. but i trust LJ more.
last question. is the Hock 3.5” long enough to make it stick out? It seems a 2.5” plane height would make a 3.5” blade @ 45degrees barely long enough.
Derek Cohen
#3 posted 12-03-2018 03:58 PM
Hi Mark
Here are two Krenov planes – one is a high angle smoother, and the other a low angle block plane …
This is a cutaway …
Link to the build: http://www.inthewoodshop.com/ShopMadeTools/BuildingaKrenovSmoother.html
I’m not sure how long the Hock blades are, but they were developed specifically for Krenov.
Regards from Perth
Derek
