Best router bit for sign making
Forum topic by SethA73 posted 12-02-2018 10:04 PM 708 views 0 times favorited 5 replies Add to Favorites Watch
View SethA73's profile
SethA73
14 posts in 900 days
12-02-2018 10:04 PM
What is the best bit for sign making? I used a rounded bit and found it left lines. I would like to have a nice smooth finish on the base of each letter. Also is Milescraft the best kit for sign making? Thank you.
5 replies so far
View BattleRidge's profile
BattleRidge
126 posts in 824 days
#1 posted 12-02-2018 10:18 PM
I have the Rockler “State Park Font” signmaking kit and like it really well. Simple to use and provides an attractive sign. They have a router bit available for each of the different sizes of letters.
-- ~Art~
View Gene Howe's profile
Gene Howe
12002 posts in 4037 days
#2 posted 12-02-2018 10:26 PM
This might pique your interest.
Signs
View John Smith's profile
John Smith
2135 posts in 771 days
#3 posted 12-02-2018 11:58 PM
can you post some photos of the work that you have done
that you are not necessarily satisfied with?
are you using templates or routing freehand ?
router bits are chosen for the type of work you are doing
and the type of wood you are using. (and the type of router).
[assuming you are not using the CNC ?].
-- I am a painter. That's what I do. I paint things --
MrUnix
7597 posts in 2807 days
#4 posted 12-03-2018 12:10 AM
No such animal.. there are too many different ways/techniques to make a sign. You need to be more specific…
- SethA73
If you want a smooth finish, then use a straight bit, which has a flat profile. Rounded bits are great for doing backgrounds where you want to have a ‘hand carved’ look with a semi-rough finish.
View Kelly's profile
Kelly
2637 posts in 3552 days
#5 posted 12-03-2018 12:42 AM
I’ve always just used straight bits. The size depended on if I was outlining or removing a lot of stock. This remains the case whether I free-handed, like these, or use my carving machine.
