Apple wood wreath
Forum topic by SethA73 posted 12-02-2018 09:51 PM 449 views 0 times favorited 4 replies Add to Favorites Watch
View SethA73's profile
SethA73
14 posts in 902 days
12-02-2018 09:51 PM
Lumberjocks,
I have some fresh Apple wood branches and I am looking to make slices and then turn them into wreaths. What is the best way to dry the slices? They are about 2-3” in diameter. Thanks so much.
View therealSteveN's profile
therealSteveN
4658 posts in 1184 days
#1 posted 12-04-2018 09:28 PM
I think if it were me I’d form them green, and allow them to dry formed. LOML does this often, she also makes baskets from riven wood, and greatly prefers hardwoods to be wet, over dry when trying to shape them.
2 to 3” diameter is gonna be tough to bend without a solid form, and at that size on a limb, I’d think hot, wet, and steamy would work best. I personally would limit my thick ends to be around 3/4” max, with 1/2” being optimal for making a “frame” to lace the thinner pieces into. Now if you had thicker pieces if you don’t turn, or smoke meats I’d see if local turners might want that bigger stuff.
-- Think safe, be safe
View PCDub's profile
PCDub
153 posts in 854 days
#2 posted 12-05-2018 03:44 PM
Lumberjocks, I have some fresh Apple wood branches and I am looking to make slices and then turn them into wreaths. What is the best way to dry the slices? They are about 2-3” in diameter. Thanks so much.
- SethA73
Looks like the OP is not bending branches to make wreaths. We might need more explanation of the desired end result.
SethA73
#3 posted 12-05-2018 03:54 PM
I apologize for any confusion my Apple wood wresth question raised. I am not bending the branches. I am making slices.
View LesB's profile
LesB
2318 posts in 4053 days
#4 posted 12-05-2018 05:56 PM
Your best bet would be a wood stabilizer like Polyethylene glycol. Soak the slices in it for the period suggested on the label. Pentacryl (exact chemical content unknown to me) would work too
-- Les B, Oregon
