PC 890 router - unexpected increase in depth of cut
Forum topic by trsnider posted 12-02-2018 03:08 AM 922 views 0 times favorited 6 replies Add to Favorites Watch
View trsnider's profile
trsnider
168 posts in 2612 days
12-02-2018 03:08 AM
Topic tags/keywords: porter cable router 890 depth of cut problem router
I have a Porter Cable 890 router in an 8901 router base mounted (upside down) in a router table. While cutting dados for drawer fronts this afternoon I noticed that the depth of cut increased so much (more than 3/16”) that the bit was almost coming completely through the drawer side. I thought that the bit was loose and had worked up while cutting but that wasn’t the case. The bit was still firmly seated in the collett. I then thought the clamping lever was loose however it was as tight as it could go while being able to completely close.
Now I’m at a lose as to what caused the depth of cut to increase so much without an obvious cause. Any ideas?
Is there a reasonably priced router better suited for mounting in a router table than the PC 890? I’m getting pretty fed up with this one.
Thanks
View wichman3's profile
wichman3
96 posts in 1223 days
#1 posted 12-02-2018 03:23 AM
Based on your observations and the symptoms, I would say that the collet is worn out and is not clamping the bit properly anymore. Replace the collet.
I had this happen to a Dremel I was using as a router and replacing the collet fixed it.
View Hammerthumb's profile
Hammerthumb
2989 posts in 2577 days
#2 posted 12-02-2018 03:29 AM
I agree with the above comment.
Also, make sure the bit is not bottomed out in the collet prior to tightening. This could also have the results of a climbing bit.
-- Paul, Duvall, WA
View TheFridge's profile
TheFridge
10859 posts in 2088 days
#3 posted 12-02-2018 03:37 AM
Ditto. An upcut spiral bit probably doesn’t help if that’s what you have.
View JAAune's profile
JAAune
1872 posts in 2919 days
#4 posted 12-02-2018 04:07 AM
It could be a dirty collet too. They should be kept clean. Scrubbing the inside with a brass or bronze tube brush and bit cleaner solution works well.
trsnider
#5 posted 12-02-2018 09:18 PM
Ok 2nd collet slipped also, not as much, but still slipped. Guess I’ll go to the store tomorrow and buy a new one. Shucks, I hate going to the store. :( or not so much. :)
View BurlyBob's profile
BurlyBob
6889 posts in 2867 days
#6 posted 12-03-2018 01:05 AM
Another thought. Perhaps if you might consider roughing up the shaft of the router bit to improve the collet’s hold on the bit. I had a similar problem with a dovetail bit in my 890 router. If you can find some one with a sandblasting cabinet to shoot the shaft, that might be enough solve your problem.
