Powermatic 66 3ph magnetic power switch. Can I put on PM60 1ph 8" jointer?
Forum topic by Dreban posted 12-01-2018 09:49 PM 913 views 0 times favorited 3 replies Add to Favorites Watch
View Dreban's profile
Dreban
64 posts in 1253 days
12-01-2018 09:49 PM
I have a magnetic power switch off my 3 phase, 220, 5hp Powermatic 66 in a box since I had to use a VFD to run it on single phase power and that required bypassing the original power switch. I’m looking at putting in an offer on a 1980s-ish, single phase, 220 Powermatic 60 8” jointer that needs a new power switch. Are they compatible? Thanks!
3 replies so far
MrUnix
8773 posts in 3442 days
#1 posted 12-01-2018 09:54 PM
Should be, although you will need to replace the heaters for proper overload protection. However, it would probably be easier just to fix the Jointer – depends on what is wrong with it.
Dreban
#2 posted 12-01-2018 09:57 PM
The guy said the original power switch went bad. I didnt know if they were compatible since i have a perfectly good one sitting in a box. I have no idea what “replacing the heaters” means. I just know what a magnetic power switch does, and have no idea about anything else. Thanks.
- MrUnix
Dreban
#3 posted 12-02-2018 09:20 PM
Anyone else have knowledge on his? Thanks!
