Worksharp 3000 + MDF, why is my buffing compound blotchy?
« back to Hand Tools forum
Forum topic by 1tacoshort posted 12-01-2018 07:18 PM 1225 views 0 times favorited 11 replies Add to Favorites Watch
View 1tacoshort's profile
1tacoshort
45 posts in 1489 days
12-01-2018 07:18 PM
Topic tags/keywords: worksharp 3000 buffing compound
Hi All,
I’ve got a Worksharp 3000 and was trying the MDF wheel ala @StumpyNubs. I have 2 questions:
1) How do you apply the buffing compound correctly? When I try, the buffing compound doesn’t go on the wheel evenly (see photo). I’m using the Enkay #150 kit that Stumpy recommended and I’m applying the compound by rubbing it on the MDF wheel as it’s spinning (nothing seems to transfer to the disk if I do it when it’s not spinning). I’ve tried roughing up the MDF with a little sandpaper to make it more like a strop but that doesn’t work either. Recommendations?
2) The grits described on the Enkay packaging say that the Brown Tripoli is coarser than the White Diamond but Stumpy and others seem to reverse the two. I assume that Enkay is right about their own product but why would others think those two would be reversed? What am I missing, here?
Any help would be appreciated! Thanks!
-- Wade
11 replies so far
View Aj2's profile
Aj2
2656 posts in 2409 days
#1 posted 12-01-2018 07:48 PM
Too me it looks very dry, when I had my Tormek I added 3 in 1 to the leather wheel to keep the compound moving and drying out.
Maybe try one section and see if it helps.
-- Aj
View TheFridge's profile
TheFridge
10859 posts in 2097 days
#2 posted 12-01-2018 07:51 PM
I’d have used alder.
View Kelly's profile
Kelly
2639 posts in 3555 days
#3 posted 12-01-2018 08:48 PM
I’m betting a drop of oil would loosen it up and spread it.
I use a LOT of compounds on everything from an AirHandler buffing station to handheld buffers. Sometimes the dry gives just the touch up I need – on spiral buff wheels. However, I often just cup my hand, add a teaspoon of water and let the wheel run through it, which refreshes the compound and allows me to continue.
1tacoshort
#4 posted 12-02-2018 05:59 AM
So, how does this work? Put a few drops of oil on the buffing compound, rub the oil/compound into a slurry, and spread that on the MDF wheel?
-- Wade
Kelly
#5 posted 12-03-2018 01:38 AM
Exactly.
Any non-hardening oil (e.g., motor or mineral) should work.
Remember, you must stay with the grit level you were using, or you can go more coarse, but you cannot, easily, go finer.
- 1tacoshort
View CaptainKlutz's profile (online now)
CaptainKlutz
2271 posts in 2105 days
#6 posted 12-03-2018 08:31 AM
Buffing compound usually has a wax carrier. Takes some friction and heat to soften and apply to buffing wheel.
If your MDF wheel is not creating enough friction (maybe due old/dry/hard compound, or too smooth surface), pass a propane torch over the end of compound stick for ~1 second before you apply to wheel. Note – Wax will catch fire and run everywhere if you add too much flame, so add heat slowly.
+1 Like Kelly, I use water (spray bottle) to freshen up old/dry buffing wheels.
Not sure I would recommend using water on MDF surface, nor would I use oil; as I fear using too much could create de-lamination of MDF. Waxes can be softened by turpentine or Stoddard solvent (100% hydrocarbon mineral spirits), and will evaporate; so light spray (or smear) with turpentine, followed by rubbing more compound on wheel, would be my suggestion to even things out.
Best Luck.
View HokieKen's profile
HokieKen
12024 posts in 1749 days
#7 posted 12-03-2018 02:44 PM
It does take a fair amount of heat to disperse those compounds. Between the MDF’s smooth face and the slow speed of the WS, there may simply not be enough friction to melt the binder in the compound. Might try shaving the compound into a jar and mixing in some mineral spirits or turpentine to soften the wax into a more pasty consistency.
-- Kenny, SW VA, Go Hokies!!!
HokieKen
#8 posted 12-03-2018 02:45 PM
And FWIW, I have the WS 3000 and the platens and abrasives made for it work very well for me.
Kelly
#9 posted 12-04-2018 12:41 AM
I have several MDF type wheels with various compounds on them. So far, none have got even with me for getting oil on them.
Best Luck.
- CaptainKlutz
View richinva's profile
richinva
13 posts in 3110 days
#10 posted 12-04-2018 02:14 PM
”.... The grits described on the Enkay packaging say that the Brown Tripoli is coarser than the White Diamond.”
Tripoli IS coarser than White Diamond, not sure why anyone would reverse that.
You can also try a bit of iso alcohol to thin out the compounds. Just a spritz shouldn’t hurt your MDF. Then smear it around with your fingers.
1tacoshort
#11 posted 12-04-2018 03:23 PM
Thanks, everybody! I’ll give those thoughts a try.
-- Wade
