Looking for advice on selecting table saw
Forum topic by Zvonko posted 11-30-2018 06:58 PM 937 views 0 times favorited 23 replies Add to Favorites Watch
View Zvonko's profile
Zvonko
89 posts in 420 days
11-30-2018 06:58 PM
Topic tags/keywords: tablesaw
Hello,
I stumbled across this site as I was looking for table saw reviews. I recently retired and want to spend more time building stuff and making renovations to my house.
The search that brought me here originally was a search for reviews on the DeWalt DW745S. The post I found here had good things to say about it, but said that one thing people regretted after buying it was that it couldn’t take dado blades.
Reading more about that, I can see how useful having that feature is.
The first model I looked at was the DeWalt DWE7491RS. It’s a bit pricey, but it seemed like it would be something I wouldn’t “outgrow” quickly. Other than the price, the main thing that discouraged me about it is the weight. Moving it around on one floor shouldn’t be a problem with the wheels, but lugging it up/down steps would be difficult given the 100lb weight. And, I’m not getting any younger :(
This is making me take a step back. Early on in my research I seem to have gotten blinders on about DeWalt and that was all I focused on.
Sorry for the novella. What I’m hoping to get from all you experts is:
1) What features should I look for in a table saw?
2) What saw(s) are your favorites?
3) Any tips/tricks on researching saws?
4) Things to be aware of when researching? For example, one review I read about said a saw’s table top was plastic and that wouldn’t hold up well. I would never have thought of that.
Thanks in advance for any feedback.
Zvonko.
—You can’t always control WHAT happens, but you can always control HOW you respond.
-- You can't always control WHAT happens, but you can always control HOW you respond.
23 replies so far
View GrantA's profile (online now)
GrantA
2128 posts in 2014 days
#1 posted 11-30-2018 07:18 PM
Welcome!
First, unless you NEED to move it up and down stairs or to jobsites regularly, move past the portable saws and on to either a contractor saw (open stand with motor hanging out the back) or a cabinet saw (enclosed stand with motor inside).
If you’re willing to put in some elbow grease look to the used market for a cabinet saw. Any of these can have a mobile base added.
As far as what to look for, the fence is key on a table saw. Dont fret though you can upgrade a fence if you find a good deal on a saw (not on a portable saw though). If you’re stuck on a portable I’d say the fence is the biggest deciding factor and the dewalts seem to be liked. I can’t comment on them though for lack of hands on experience
View Bill_Steele's profile
Bill_Steele
633 posts in 2338 days
#2 posted 11-30-2018 07:23 PM
Welcome to Lumberjocks.
I feel like it is important to understand the general tablesaw categories and then pick from the category that seems to make the most sense for your needs.
The DeWalt DWE7491RS looks to be a job-site saw which is more geared (in my opinion) toward the user that needs to move the saw from jobsite to jobsite. It is more portable but you give up capability in other areas to get portability.
The next category up is probably contractor saws and hybrid saws. These are heavy—not really portable (except around your shop area by using a mobile base). The weight is good thing because it makes the saw smoother in operation. These saws usually have a larger motor than a job-site saw, often they have a cast iron top, a larger saw surface area, and the fence is likely better than a job-site saw (more rip capacity and fence accuracy). This is probably the minimum level you want to be at for more precise cuts and/or if you want to perhaps build furniture or something that requires a higher degree of accuracy.
The next category up is cabinet saws. These are even heavier and more powerful than the contractor saws. Much better fence system, dust collection, etc. Most have 3hp or larger motors (some are offered with motors that can run on 110v but the larger motors require 240v. Still locally portable with a mobile base. I aspire to this level.
Based on your need to do things around the house—if you can dedicate an area for the saw—I would suggest a contractor, hybrid, or cabinet saw. I think it will give you more flexibility, perhaps more accuracy, and allow you to explore other woodworking options (e.g. making furniture).
I’m sure there must be posts on this site that also talk about the pros and cons of the different saws. Try and perform a search of the site for more information. I hope that helps.
117908 posts in 4183 days
#3 posted 11-30-2018 07:51 PM
Hello and welcome to LJs
Your question is one that is asked almost every day so searching this site will bring a good number of answers to your question. I would suggest you look at this blog by in my opinion is LJs #1 table saw guru.
http://lumberjocks.com/knotscott/blog/32154
View jonah's profile
jonah
2092 posts in 3905 days
#4 posted 11-30-2018 09:22 PM
+1 to reviewing Scott’s writeup. He lays out all the choices nearly perfectly.
View SMP's profile
SMP
1593 posts in 512 days
#5 posted 11-30-2018 09:48 PM
I think you first need to sit down and think about what you want to make and do with it. What will you be actually building and how often? And what other tools do you have? For example, if I didn’t need to rip smaller stock often, I would probably ditch my table saw altogether and get a track saw like the Festool. I also have a sliding compound miter saw that does most of my crosscuts and miters. I can also rip with my circular saw and clean up on my jointer. But a table saw is really hard to replace for certain things. Again, depends on what you need it for. If the portability of the smaller interests you, and you can cut dados with a router, then the dado blade thing may be a non issue. A lot of variables.
View Holbs's profile
Holbs
2262 posts in 2635 days
#6 posted 12-01-2018 12:29 AM
I’ll make it simple for ya, Zvonko.
buy a used Bosch 4100 off craigslist.
Done! :)
Seriously, it’s a great table saw as it accepts 5/8” dado’s. A wonderful primary saw if $$$ and real estate is a concern, especially if you get the gravity rise stand. Has all the necessary safety features, minus sawstop flesh sensing capability (well…that’s another story).
And later on when you upgrade to a hybrid or cabinet saw, it’s still a wonderful secondary saw for outside cutting (plywood, mdf, etc).
For folks to advise you on what table saw to seek out, give us a backstory of your power tool experience and what you are expecting to work on today and 5 years from now.
View Sludgeguy's profile
Sludgeguy
57 posts in 729 days
#7 posted 12-01-2018 02:03 AM
Agree with Holbs. I had the Bosch for several years until I got a cabinet saw. The Bosch was very precise and reliable. Decent power especially with a thin kerf blade.
Holbs
#8 posted 12-01-2018 04:48 AM
ooo…impossible quiz! tell me more…
how much would be deducted out of my checking/credit card account?
View knotscott's profile
knotscott
8359 posts in 3982 days
#9 posted 12-02-2018 04:20 PM
I’m late to the party, but would advice to skip a portable of you don’t absolutely need portability. The better portables are pretty good, but they give up a lot compared to a full size stationary saw with a belt drive induction motor. The biggest drawback of the portables IMHO is the table size….there are only a few inches of table surface to get a board settled and flush with the table before it contacts the blade. Also, an induction motor has a lot more torque, better reliability expectations, and are much quieter. The added mass is also a notable plus, not to mention the ability to accept aftermarket accessories so the saw can grow with your needs. A 300# saw will undoubted require a couple of strong guys to set in place, but once there, it can be put on wheels and easily rolled around a sheep for reliable service for years to come.
Zvonko
#10 posted 12-04-2018 12:25 PM
Wow, thanks for all the responses. I’ll try to answer some of the questions/comments below:
I don’t have a need to move the saw around to job sites, but I do need to be able to move it around since my “shop” is my garage. Usually, when I need to work on some project, I’ll have to move my power tools around the garage or even into the driveway.
Compared to the people I’ve seen on this site, I’m probably not much above a beginner. My woodworking experience has been mostly “rough carpentry” (my term) with very little “finish work” (again, my term). For a while, I was maintaining 20 rental units and did most of the work on them. Maybe I’d be better categorized as a handy man instead of a woodworker.
I want to start doing more intricate pieces and work my way up to making some nice furniture. At some point, I’d love to build a real nice dining room table.
My inventory of power tools is not extensive beyond the basics: electric & cordless drills, jig saw, reciprocating saw, brad nailer and circular saw. I do have a real nice 12” Craftsman compound miter saw and a big 30-year old Craftsman 10” radial arm saw.
The miter saw gets a lot of use and I’ve been able to cut wood with it to build some small boxes, bird houses, shelves, etc. At the time I bought it, they didn’t have (or I didn’t see it) the sliding feature I’m seeing in some miter saws now.
The radial arm saw has gotten a lot of use and is still my work horse for big cuts or ripping wood. It’s big, though, and a hassle to get out and move (I put it on a wheeled platform) into the driveway. As a result, I only get it out when I have to do a lot of cutting.
A table saw seems like it will fit the needs between the miter and radial-arm saws and be a lot easier to move around than my huge radial-arm saw.
Zvonko
#11 posted 12-04-2018 12:38 PM
I forgot to mention that I also have a router and have a fair bit of experience using it. Additionally, I have a Dremel tool for fine work and just bought an old lathe (heavy sucker) from the grandpa of a friend. I haven’t tried the lathe yet, but I’m really excited to use it!
jonah
#12 posted 12-04-2018 03:54 PM
Given that you are only moving the saw around the garage area, I’d look for a quality contractor saw, not a jobsite one. You’ll be much happier with that type of saw, and on the used market they don’t cost a lot more than good new jobsite saws.
Look for a Rigid 3650 or a Craftsman saw of similar vintage (5-15 years old). You shouldn’t have to pay more than ~$300 and you’ll get a quality saw that is very movable on the mobile base.
View Joeswoodshop's profile
Joeswoodshop
5 posts in 417 days
#13 posted 12-04-2018 04:08 PM
Given that you are only moving the saw around the garage area, I d look for a quality contractor saw, not a jobsite one. You ll be much happier with that type of saw, and on the used market they don t cost a lot more than good new jobsite saws.
Look for a Rigid 3650 or a Craftsman saw of similar vintage (5-15 years old). You shouldn t have to pay more than ~$300 and you ll get a quality saw that is very movable on the mobile base.
- jonah
This^^
I have a Ridgid 3650 with a router table wing that works great. I have to move it a lot and it has a built in lift that makes it easy.
View Robert's profile
Robert
3602 posts in 2087 days
#14 posted 12-04-2018 04:32 PM
If you need to move the saw up and down stairs, I think your best best is a jobsite saw. There are some decent ones out there stay with the name brands. IMO any beginner should look at a SawStop. They make a good quality jobsite saw. I’m sure your loved ones will appreciate the safety features.
When your renovations are over and you think you want to do mainly shop work, when you outgrow it you can sell it and buy a stationary cabinet saw. All but the biggest will take a mobile base.
Now I want to say something unrelated but in your post. SAFETY is such an extremely important issue for a beginner. I can’t emphasize it enough. Do some reading, take a class, watch some videos. Always keep SAFETY in mind when making a cut. Learn the limitations of your machines. Learn to read your lumber before feeding it past a blade. By this I mean look for bows, loose knots etc. Learn how make assist devices like push blocks and use them properly. Know where your hands are at all times.
Speaking of safety, I strongly advise against doing rip cuts with a radial arm saw. It is THE most dangerous procedure on probably THE most dangerous machine in a shop.
The second thing I want to address is regarding one of the biggest mistakes we make as beginners and that is develpoping hand tool skills. As a beginner my self (even after 30 years of ww’ing) I did the same thing. IMO “fine” woodworking or excel at craftsmanship is not possible without hand tools.
Some will disagree with me on this, but try fitting a drawer or door without a hand plane & trust me all you’ll be doing is making a lot of dust with a sander or over shooting trying to dial it in with a saw.
I want to encourage you so much about this. Get a #4 hand plane, a set of bench chisels, a couple good hand saws, and some marking tools. Do some research and find out what the quality tools are. Fine Woodworking magazine has excellent reviews on all these. Just their video library alone is worth the membership fee.
Good luck hope this helps.
Check out Paul Sellers he will be an excellent source for you.
View ChefHDAN's profile
ChefHDAN
1498 posts in 3456 days
#15 posted 12-04-2018 05:06 PM
- jonah
Completely agree, it sounds like you’d quickly outgrow a jobsite saw, and you’ll need the size and power when you get around to that dining room table. I’m in a 2 car and can actually put a mid sized car into the garage when all of the tools are put away. I’ve got one of the Ridgid saws, (TS3612 with rails from a TS3650), and they were pretty much the same saw as the craftsman 113 saws. They come up often of Craig’s list like jonah said in the $200 $300 range. Kelley Mehler’s Table saw book is a good tool getting a used saw set up & tuned
