Nova Galaxi Questions
« back to Woodturning forum
Forum topic by OSU55 posted 11-30-2018 01:17 PM 640 views 0 times favorited 4 replies Add to Favorites Watch
View OSU55's profile
OSU55
2507 posts in 2598 days
11-30-2018 01:17 PM
Topic tags/keywords: question
A few questions I have not been able to find answers to:
What is the floor to spindle height?
How much adjustment height is available with the leg adjusters?
Top of banjo tool rest hole surface to spindle (not the published tool rest swing but from the very top of the banjo)?
Depth tool rest post drops into the banjo?
For the Nova modular tool rests, would the Galaxi use the 5” or 8” long post?
For the outrigger tool rest, with the spindle head rotated 90 deg, what is the max distance from the spindle chuck shoulder to the tool rest, at the tool rest post i.e. middle of the tool rest? (so I can calculate max length of a turning)
Same as above but with the spindle head rotated 180 deg?
The published lowest speed is 100 rpm. Anyone know of a way to reduce the speed more? for sanding/finishing low load activity, not cutting.
Thanks for any info you can provide.
View LeeMills's profile
LeeMills
690 posts in 1909 days
#1 posted 12-05-2018 03:32 PM
I don’t have the Galaxy but a bit of history..
Nova first had the 3000, with belt or with DVR.
They changed the name to the 1624 (belt) and the DVR XP (DVR of course).
The DVR XP came without legs and with the same 24” bed.
It appers…
They added the bed extension, included the cast iron legs, and painted it black …. now the Galaxi.
The tool rest should be the same on both.
Spindle height 42.5” where I have mine set. Adjustment max unknown (guessing 2” max), mine is up about 1”+
Top of Banjo to center 3.75”
Depth of banjo for post 4” It can go all the way through. At times I have mounted my dust collector hood inserting the post from underneath.
Length of the post on their supplied bango is 4”.
I had the outrigger but never used it expect to hold the knock out bar. IIRC Nova states max 6” depth. If interested I can find a video showing a different outboard rest which is less expensive and should work better.
OSU55
#2 posted 12-05-2018 05:33 PM
Thanks Lee ! Yes I am definitely interested in outboard toolrest possibilities
LeeMills
#3 posted 12-06-2018 01:46 AM
You can skip over to about the 3:30 minute …
Rather than $300 for the outboard the extension cost about $200. Mount your banjo and you have a much easier to move rest (20” + the toolrest length) than moving the outboard rest mounted to the lathe. And go as deep as you dare without limitations.
https://www.youtube.com/watch?v=ydDQQQww1AA
View Dustin's profile
Dustin
706 posts in 1349 days
#4 posted 12-06-2018 02:20 PM
- LeeMills
That was the most impressive thing I’ve watched all week. Appreciate you posting, Lee, and you for asking, OSU, as I’m eyeing the Galaxi for an upgrade from my Delta midi in January.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
