Stopping the checking
Forum topic by Steve posted 11-29-2018 03:36 PM 522 views 0 times favorited 5 replies Add to Favorites Watch
View Steve's profile
Steve
2213 posts in 1462 days
11-29-2018 03:36 PM
I wanted to know what I could do to stop the checking in this piece of walnut? I’ve gotten the bandsaw box bug and picked this piece up from the offcut pile to make a small box with.
My original thinking was to sandwich the piece between two pieces of maple and then put some maple dust mixed with CA glue into the check for a combo design/stability.
Question being whether the CA glue will stop the checking?
5 replies so far
View HokieKen's profile
HokieKen
15157 posts in 2018 days
#1 posted 11-29-2018 04:28 PM
Is the wood dry Steve? If it’s fairly well dried already, then chances are the checking is done. It probably occurred when the wood was green. Looks like the checking went pretty deep so I’m not sure if maple dust and CA would penetrate all the way down. I’d probably dye some epoxy and pour it in there if it were me. I think you’re probably just dealing with a design issue though rather than needing to stabilize it.
Just my $.02 of course! YMMV
-- Kenny, SW VA, Go Hokies!!!
Steve
#2 posted 11-29-2018 04:37 PM
Thanks Kenny. I’m pretty sure it’s dry, although I haven’t checked it with my meter.
I thought it was an interesting shape, so i grabbed it. I’ll try the epoxy route.
View LesB's profile
LesB
2620 posts in 4323 days
#3 posted 11-29-2018 09:36 PM
My experience is that medium thick CA glue stays fluid long enough to penetrate those cracks without a problem and usually stops further cracking. If you want to fill them with fine saw dust first I suggest using a combination of thin CA glue first to soak into the dust and immediately follow it with the medium glue. The thin glue acts as a wicking agent to draw the thicker glue in. It would be much easier than messy epoxy.
Use caution and good ventelation with this because if there is any moisture in the cracks the CA may produce fumes (sometimes visible smoke like vapor) that you do not want to breath.
-- Les B, Oregon
Steve
#4 posted 11-29-2018 09:45 PM
Just for reference, CA glue is the same thing as super glue right?
View DS's profile
DS
3571 posts in 3300 days
#5 posted 11-29-2018 09:55 PM
Cyanoacrylate = Super Glue = CA Glue
BTW, My usual method of stopping checking is to cut the checked end off of the work piece, build the project, then seal with sanding sealer. This, of course, assumes you allowed enough waste material to sacrifice a couple inches off of the ends of your checked boards.
