Help with cutting board finish
Forum topic by becikeja posted 11-29-2018 12:34 PM 668 views 0 times favorited 8 replies Add to Favorites Watch
View becikeja's profile
becikeja
1045 posts in 3415 days
11-29-2018 12:34 PM
About 2 years ago I made 3 end grain cutting boards. 1-Mahogany and maple, 1-Cherry, 1-Maple and Cherry
I finished each board by drowning in mineral oil, and then a final coat of wax. The first 2 boards I know were recoated with an oil wax mixture about every 6 months and look great.
Over Thanksgiving we traveled down to the in-laws…...… Owners of the 3rd cutting board. Maple and Cherry end grain checker board style. It had obviously been recoated with mineral oil within the last 2 days but I did not inquire as to when or what exactly was used. The maple squares had noticeable spots. What would cause this? will it dry out? Does it have something to do with the maple? I’m a little worried because since then I have sold several and really hope the others don’t develop these spots over time.
8 replies so far
View Lazyman's profile
Lazyman
4469 posts in 1989 days
#1 posted 11-29-2018 12:46 PM
Pictures or more information would help. Were the spots of wet oil or spots where the oil was repelled, for example?
Does washing the board make any difference?
becikeja
#2 posted 12-03-2018 11:09 AM
Here is a pic. Looks like she used this stuff from Ikea, appears to be just mineral oil. Doesn’t seem to explain the spots to me anyway. Any idea what would cause these spots.
Lazyman
#3 posted 12-03-2018 05:43 PM
Couple of thoughts…
  • Could those spots have still been wet when the MO was reapplied? Wet spots will likely repeal the MO.
  • Almost looks like there is a finish other than MO that repealed the MO. Perhaps the wax you applied? Try stripping the wax off and reapplying the MO. You might have to re-sand.
  • You might consider using a butcher block finish instead of MO followed by wax.
becikeja
#4 posted 12-04-2018 01:35 AM
The water spots was my guess. Almost like she washed it and then applied the mineral oil before it was dried, I just don’t know. I’m not to concerned with applying the MO on top of the existing finish. I’ve applied a wax/MO mixture on others with no bad effects.
It has to be water, I just cant think of why else this would happen.
Appreciate the response
becikeja
#5 posted 12-05-2018 11:06 AM
Update, I’m back to square one. The claim is that it was dry before the new MO was added.
Still wondering what happened here, if you have any other ideas.
Next step is to sand off the finish and reapply. But I still need to know what happened so I can understand what caused this,. My OCD is kicking in and this is driving me crazy.
Lazyman
#6 posted 12-05-2018 12:54 PM
Then my guess is that the wax is part of the problem. The spots may be where the wax has come off allowing the MO to soak in but the other areas where the wax is still thick enough repealed the MO.
View LesB's profile
LesB
2301 posts in 4044 days
#7 posted 12-05-2018 06:05 PM
I would guess that because it appears the spots are in the central cutting area of the board that some other contaminant had gotten into the wood. You could try washing the board in a detergent (dishwasher detergent) or appropriate solvent and retreating to see if that removes the spots.
I’m not a fan of mineral oil on cutting boards because it never “dries”. I have had much better luck with other oils that “cure”, like processed Walnut oil which soaks in and cures hard. It too can be replenished as needed and on appropriate surfaces can even be built up into a surface coating. Tung oil is another that “cures” hard. Note I use the word cure because these finished do not dry the chemically cure and in most cases help harden the surface of the wood.
-- Les B, Oregon
View Aj2's profile
Aj2
2647 posts in 2399 days
#8 posted 12-05-2018 06:17 PM
Are you taking about the dark areas I’m the middle of the maple? Because I’ve seen maple have that look after being glued. The water from the glue is being absorbed by the wood. The dark areas in the middle of your work looks like walnut dust dropped in the pores and got trapped.
Or maybe even the moisture from the glue was trapped when closed out the cells with mineral oil.
There’s my guess from a thousand miles away :)
-- Aj
