Router: Edge Guide Build Advice
Forum topic by MSquared posted 11-29-2018 05:26 AM 945 views 0 times favorited 23 replies Add to Favorites Watch
View MSquared's profile
MSquared
953 posts in 515 days
11-29-2018 05:26 AM
Hey All!
Picked up a 320.27683 Router Combo on CL. Fixed and Plunge Base, and all accessories, BUT the edge guide!
Any ideas on a shop-made router edge guide? I’m figuring something sturdier and more accurate than stamped metal would be well worth making in the shop. I’m all ears! Thanks!
-- Marty, Long Island, NY
23 replies so far
View ChefHDAN's profile
ChefHDAN
1496 posts in 3450 days
#1 posted 11-30-2018 02:00 PM
From looking at the pics I can find of the model it looks a bit like a PC clone, and the $40 PC edge guide is VERY good. From the pic in the link you can see it has two sets of posts to fit different spacings, I use mine on my PC’s and it also fits my little Dewalt 611. I do have to say though that with a router table or straight edge clamps and most edge forming bits available with bearing guides I do not often find a need to go to the work of mounting the edge guide.
MSquared
#2 posted 11-30-2018 05:23 PM
Thanks ChefHDan. Looking around LJ, I came upon a1Jim’s suggestion;
http://lumberjocks.com/projects/7953
I was wondering how useful an edge guide would be anyway. Is it a must have or a nice to have?
View SMP's profile
SMP
1558 posts in 507 days
#3 posted 11-30-2018 05:29 PM
Thanks ChefHDan. Looking around LJ, I came upon a1Jim s suggestion;
- MSquared
Personally I have never felt the need for an edge guide, but I guess it depends on what you are building and how many. I think in times it would have ever been of use, its better just to use my router table. YMMV.
View HokieKen's profile
HokieKen
11982 posts in 1739 days
#4 posted 11-30-2018 05:33 PM
- MSquared
Mine is still in the original packaging if that answers your question… Of course if I didn’t have a router table with fence, that would be a different story.
-- Kenny, SW VA, Go Hokies!!!
View Andybb's profile
Andybb
2334 posts in 1204 days
#5 posted 11-30-2018 05:43 PM
For me it’s a “nice to have”. Think I used mine once right after I got it 5 years ago as some other jig or fence setup always seems better suited for the job. A lot depends on what you are doing and what kind of set up you have. I’d suggest getting (or building) a fence and table combo first (or table saw wing insert) and go from there. $40 is certainly affordable and a time saver but there are many DIY edge guides that can be made from scrap and work just as well. Spend the $40 on a good bit or two. Then after you get tired of bending over to adjust the height of the bit in your table, buy a lift, then Bob will be your sisters brother.
As an example, I have a Bosch 1617 and bought the edge guide for it as it had a very nice adjustment knob and a few other bells and whistles that the marketing folks did a good job of convincing me that I needed. Used it once. I can get the same stuff done using the fence twice as fast. Yes, it’s great to be able to micro adjust the edge guide but a slight tap on the fence does the same thing for me.
youTube is your friend. DIY router edge guides DIY router fences
JMHO
-- Andy - Seattle USA
Andybb
#6 posted 11-30-2018 06:04 PM
Sorry. Double post.
HokieKen
#7 posted 11-30-2018 07:27 PM
Would that be this guide Andy?
‘Cause that’s the same one I still have in the package :-)
Andybb
#8 posted 11-30-2018 08:24 PM
^ Yep. Used it once. It’s in a drawer somewhere.
MSquared
#9 posted 12-01-2018 12:03 AM
Thank you all for your replies! Your answers to my ignorance will hopefully benefit others as well myself. I’m getting an education. Well, pictured below is what I have to work with. Keeping in mind I’m still getting a very small garage shop together and taking stock of what tools I have on hand. I’m sure there are parts lurking around somewhere yet to be found. I do have a router table with fence. Two, in fact. I plan on building a router table with storage down the line. I figure one of these will suffice for the time being. The Routers are; Porter Cable 1002 ( fixed base), C-Man 315.17461 (fixed base) and C-Man 320.27638 (fixed and plunge base). The C-man 320. I recently purchased on CL appears to have all the accessories…not all pictured. (except for the edge guide! Hence, the reason for my beginning this thread)
Your opinions? Got some keepers there?
PS; Sorry. Couldn’t figure out how to rotate the hastelly taken pix. And don’t even mention that pink wall. I’ll get to it!
Regards,
Andybb
#10 posted 12-01-2018 12:10 AM
Since you have both bases for the C-man I’d put the PC in the table. My Bosh hasn’t seen the light of day for close to 4 years. I use a PC and a small Dewalt and a cheap Harbor Freight one that has a round-over bit that lives in it.
PS . Talk about the ultimate router table….watch this vid
MSquared
#11 posted 12-01-2018 12:50 AM
Whoa! That’s a mind-blower, very cool!
In the meantime, are what I have viable tools? Sounds like you recommend keeping the PC installed in the table. It appears that the newer table is more functional. Let the older one go?
Andybb
#12 posted 12-01-2018 01:40 AM
Whoa! That s a mind-blower, very cool!
- MSquared
Up tp you. I’m just saying that taking routers in and out of a lift or table is a pain so decide which one you want in the table and leave it there. Even though it may seem counter intuitive you want to use the fixed base for mounting in the table unless the table has a different way to mount the router without a base. The PC has a way of “adjusting the height from the top of their routers once it’s mounted under the table. Don’t know about the Craftsman.
MSquared
#13 posted 12-01-2018 03:43 AM
Ah! Thanks Andy. Very good point. That router looks a lot like what I have. Gotta take a better look at the tables.
View bandit571's profile
bandit571
24345 posts in 3284 days
#14 posted 12-01-2018 04:11 AM
Look like yours?
I can use a simple Allen wrench to adjust heights with…
Have used to edge guide for this router several times…
Had 4 webframes ( for drawer guides) that I ganged up to route sliding dovetail pins…
This is how the edge guide looks…..
I do have another model’s edge guide…looks close to the same size…rods are set a tad narrower. router for it is long gone…and I keep confusing which is which….let me know if you want it.
MSquared
#15 posted 12-01-2018 04:27 AM
That’s the one Bandit! Sure, I’d be happy to have it! It would be a good addition to the shop. Especially once you tell me the story behind those dovetails! .... and how to do it :0)
