Simple Question: Table Saw Stand
Forum topic by NeophyteGrant posted 11-27-2018 08:32 PM 837 views 0 times favorited 4 replies Add to Favorites Watch
View NeophyteGrant's profile
NeophyteGrant
147 posts in 1758 days
11-27-2018 08:32 PM
Topic tags/keywords: table saw mobile base casters
Hopefully this is a simple question, nay clarification. I’m apparently going through a dense period where I can’t think for myself.
This comes from another thread: http://lumberjocks.com/Brad_Nailor/blog/11845
I have 4 different mobile base models but in a small, tight shop, the parallel parking of 2 fixed, 2 swivel casters is becoming annoying (I want the drift!, One touch push!) So, I’ve committed to building this.
One question: It looks like bolts, oriented down in the photo? But bolts or screws on this? If I screw I’d imagine since the weight is oriented down that I want to go through the 3/4 inch ply base from the bottom up, so as to push the screw through the entirety of that 3/4 inch….
View HokieKen's profile
HokieKen
19438 posts in 2388 days
#1 posted 11-28-2018 02:05 PM
I’d leave off the 3/4” ply unless you need the bottom enclosed for some particular purpose. I don’t see that it’s really gonna add anything structurally. Then I’d just screw the lumber together. I built a similar base a couple of years ago for my jointer using only 2×4s and it’s held up well.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
NeophyteGrant
#2 posted 11-28-2018 09:02 PM
Thanks Kenny. That makes sense. My thought in including the plywood was that it would get me closer to the ground. One of the machines is a Drill Press, and I had thought to put it closer to the ground since it’s top-heavy. For other machines I don’t know if there is a benefit, though. Does it make it less liable to slide it the center of gravity is lower? (I have double locking, 3” poly casters I’ll use, and I haven’t had a need to have any of my shop casters be very still—the consumer stands all are the ones’ that rest on rubber feet and are lifted up by pedal). I have no clue.
But…my stupid question of the day is what size screws? Does it actually need something like a 1/4 or larger thread?
Congrats on taking down UVa this weekend. We have a kid at our office from UVa. Nice kid, but sort of insufferable. Watching his misery in the wake of that game was schadenfreude. Cruel, I know, but it was entertaining to rib him about UVa’s basketball and football mishaps.
HokieKen
#3 posted 11-28-2018 10:16 PM
I was at that game. It was miserably cold but I’m glad I toughed it out :-)
I’d use a #12 screw in construction lumber. The wood is soft so the coarser the thread the better. But honestly, you could probably use drywall screws.
The main concern for center of gravity is when you have a top heavy machine like a drill press. I wouldn’t worry with a table saw personally.
View WoodenDreams's profile
WoodenDreams
1433 posts in 1160 days
#4 posted 11-28-2018 10:38 PM
This design is less expensive than a $80 or $90 roller base
