Spraying shellac in cold garage
Forum topic by dataz722 posted 11-27-2018 05:48 PM 1035 views 0 times favorited 12 replies Add to Favorites Watch
View dataz722's profile
dataz722
28 posts in 1158 days
11-27-2018 05:48 PM
I have a bunch of stuff that I need to finish that has been piling up. I typically spray lacquer, but with my garage hanging around 40-55 degrees I don’t want to use that since I won’t be able to keep the garage doors open to let the fumes out and can’t run my kerosene heater without risking blowing myself up. I don’t really like any water borne stuff I have tried in the past so that just leaves me with shellac (I need something that can be done quickly). I have never had much success in brushing or wiping shellac for some reason so I would want to try spraying it. Will the colder temperature be a problem? Or can anyone see any issue with using the heater to warm up the garage, turn it off while spraying and then after a few minutes turn it back on again?
Thanks
12 replies so far
View pintodeluxe's profile
pintodeluxe
6038 posts in 3422 days
#1 posted 11-27-2018 05:56 PM
Treat shellac just as you would lacquer or poly… as a solvent based coating. All the same precautions apply.
You’ll need to pre-heat the garage, then vent as you spray. Once the fumes have dissipated, close the doors and heat the garage again as the finish cures. Be mindful of any ignition sources such as a furnace or pilot light.
View Aj2's profile (online now)
Aj2
2651 posts in 2406 days
#2 posted 11-27-2018 05:59 PM
Not know your full setup it’s nearly impossible to say for sure if it’s a good idea. I do know one thing for sure Denatured Alcohol is very bad to breathe or get on your skin in long large amounts.
I work a lot with shellac and I’m lucky I haven’t experienced any drain bamage. :)
-- Aj
5929 posts in 3102 days
#3 posted 11-27-2018 06:24 PM
Shellac can be successfully applied in some pretty cool temps, I’ve used it down to 40º with no problems. That does slow down the evaporation of the alcohol slightly, but otherwise it works fine. You will want to prepare for the personal exposure issues, but otherwise you should be good to go. As always, if this is your first try, do an experiment to make sure you have all the bases covered.
dataz722
#4 posted 11-27-2018 07:19 PM
I always wear a respirator so I am not worried about breathing it in, although I am probably due for new filters. I didn’t think about the skin exposure though, so thank you. I’ll make sure to wear long sleeves and glasses or goggles. It is also really good to know that shellac is fine at colder temps. I will probably just heat the garage up pretty high and then not turn it back on after. If I get it up to 80 it will take a couple hours for it to drop back down below 50
View DrDirt's profile
DrDirt
4600 posts in 4351 days
#5 posted 11-27-2018 08:00 PM
Indeed still solvent base, so you have the aerosols in the air, posing a danger with your heater.
Certainly the Ethanol is less exciting than lacquer thinner.
For the poison side… if you are worried about that, go buy a bottle of everclear from the liquor store… it is the same ethanol, but without the nasty “Denatured” aspect. (NOT the Everclear 151…that stuff is only 75% alcohol you want the 190 proof 95% stuff)
dataz722
#6 posted 11-27-2018 09:43 PM
I’m not too worried about it. Hell, with where I live some other environmental thing will give me cancer and kill me long before using a little shellac. It does make me wonder though which is cheaper, the everclear or the DNA.
View MrRon's profile
MrRon
5812 posts in 3852 days
#7 posted 11-28-2018 08:47 PM
I m not too worried about it. Hell, with where I live some other environmental thing will give me cancer and kill me long before using a little shellac. It does make me wonder though which is cheaper, the everclear or the DNA.
- dataz722
Breathing everclear is not a good idea. It is odorless and will make you drunk before you know it.
DrDirt
#8 posted 11-30-2018 10:38 PM
- MrRon
Should be wearing an organic vapor respirator when spraying… but it is no more intoxicating than spraying shellac dissolved in Denatured Alcohol… both are Ethanol, DNA just has few % poison added to it.
View Pogo930's profile
Pogo930
18 posts in 1251 days
#9 posted 11-30-2018 11:56 PM
The big box stores are carrying “green” alcohol. Comes in a quart can with green on blue labelling. Look up the MSD sheets. Green is 95% ethanol, regular runs as low as 50-60%. ts a little more expensive but I don’t want to be sucking 40% wood alcohol.
MrRon
#10 posted 12-01-2018 04:44 PM
- DrDirt
Are you aware that everclear is grain alcohol, not wood or denatured. It is sold in liquor stores and people use it to make their own liquors. It is 190 proof (95% alcohol) and it will make you drunk. Way back when I was a young man, we used to add it to a coke and get blitzed very quickly. It is odorless, so no one could accuse us of drinking on the job. It is also very flammable.
DrDirt
#11 posted 12-03-2018 02:20 AM
- MrRon
Mr ROn – - DNA is Grain Alcohol (Ethanol), with some methanol added to make it poisonous.
Methanol also will make one drunk, but also blind.
As such – breathing DNA will make you as drunk as Everclear, but with other negative effects.
SO why not spray the “Non-Poisoned” version of ethanol- wearing PPE as you would using any organic solvent?
Perhaps look at this first
https://www.thoughtco.com/what-is-denatured-alcohol-p2-603999
dataz722
#12 posted 12-05-2018 08:54 PM
- dataz722
- MrRon
So two birds one stone?
That was a joke, just to be clear.
