Drawer face treatment
Forum topic by deadherring posted 11-27-2018 04:17 AM 489 views 0 times favorited 4 replies Add to Favorites Watch
View deadherring's profile
deadherring
83 posts in 2246 days
11-27-2018 04:17 AM
Hi all,
I just finished a floating desk made from walnut, mahogany, oak and maple—pictures below. It is 2” thick and I am going to make two drawers from 1/2” ply that I will install under the desk to hold papers and stuff.
I am deciding on how to face the drawers. The desk came out great and looks super sharp and I am thinking about how to make drawers that go along with the sharp look.
I have some leftover walnut so I think I am going to use that for the face. I was thinking of a few different options to dress up the plain walnut:
1. wrapping the walnut in maple, mitered at 45 and maple drawer pulls.
2. Maybe doing some kind of edge treatment with a router bit? I’ve never done that before so any suggestions or links to bits is appreciated.
Happy to accept additional suggestions. Pictures and links are always helpful.
Thanks all!
Nathan
View bilyo's profile
bilyo
959 posts in 1705 days
#1 posted 11-27-2018 03:47 PM
This is a question of aesthetics and, therefore, is a matter of opinion. Mine is that drawers (or anything else) under the table probably should not draw attention and should be of simple unobtrusive design. I think the choice of walnut would be perfect, but don’t go big with embellishment. Maple pulls would be as far as I would go. IMHO.
Nice work on the desk. Looks great.
View Bill_Steele's profile
Bill_Steele
630 posts in 2334 days
#2 posted 11-27-2018 04:07 PM
Nice job on this project—I think your floating desk great! What do you use to support the desk? I have a floating desk that I made out plywood and MDF (total thickness 1.5”) and I support it with a series of double slot shelf support brackets.
The high contrast in the color of the wood you chose is visually interesting and is really the “star of the show” here. I would probably tend to go with something simple (a single wood) for the drawer—like bilyo suggests. Don’t try to draw the attention away from top. I would also consider NOT adding drawers to the desk if the drawers will limit the range of motion where you can move your chair under the desk. Maybe a small rolling cabinet that has drawers if range of motion is limited by the drawers.
I added a wire chase/shelf below my desk where I run all my wires, surge protectors, sub-woofer, router, etc.)—it helps keep the desk surface a little clearer.
deadherring
#3 posted 11-27-2018 10:30 PM
Thanks guys.
@bilyo I used these brackets: https://ironsupports.com/collections/hidden-countertop-brackets/products/standard-front-mount-countertop-l-bracket
@Bill_Steele- I made a small box that is flush with the wall and faced with walnut to hide all the wiring.
20” for the large section and 12” for the short section.
Re: the drawers: the range of motion won’t be restricted. I will mount all the way to the right side, flush with the desk edge.
Now that I think about, i think you guys are right about not drawing attention away from the desk (both my wife and daughters said the same thing!). I will go with just walnut.
Do you think I should just do a regular edge—i.e no other treatment to the edge of the faces or route a profile of some kind?
Thanks!
Nathan
bilyo
#4 posted 11-27-2018 11:23 PM
Your preference. Your desk edges look like a simple round over. You might consider being consistent with that.
