Do magnetic sheets work ?
Forum topic by Vintagewood1960 posted 11-26-2018 08:03 PM 719 views 0 times favorited 13 replies Add to Favorites Watch
View Vintagewood1960's profile
Vintagewood1960
52 posts in 1101 days
11-26-2018 08:03 PM
I’m getting ready to talk some friends into a bulk buy of some magnetic sheeting. I live in Northeast Georgia and heat my insulated (two garage door) 900 square foot shop with a propane torpedo style heater. Condensation is not too bad on my cast iron tops most of the time. But… When it’s bad it’s dripping bad and the more large tools I acquire the bigger the problem becomes. So.. I’ve been looking at magnetic sheeting as an option. I can leave the sheets in place until I get the room temp up and then remove. I’m looking for some testimonials that these magnetic sheets work. I have a concern that I may just end up trapping existing moisture between the table and the sheet and create rather than alleviate a problem.
13 replies so far
View John Smith's profile
John Smith
2131 posts in 767 days
#1 posted 11-26-2018 08:11 PM
what is the purpose of the mag sheets ? where will you put them ??
and YES – magnetic sheets trap moisture underneath them if not removed
often enough. and it sounds like your use will be short term. but, I would
avoid long term use on cast iron.
I had my tools in a greenhouse for a year and it also got dripping wet like you describe.
I covered the metal machines with a painters drop cloth then plastic on top of that.
magnetic sheet is designed so it won’t fall off of something, like advertisement on a truck door.
for table saws, jointers, drill presses, etc. why not use something that can breathe when it gets damp.
[plus, moving it around the shop, it will pick up every small piece of metal it comes in contact with].
but -magnetic sheets for moisture protection ??? please explain a little more.
-- I am a painter. That's what I do. I paint things --
5923 posts in 3097 days
#2 posted 11-26-2018 08:31 PM
Some time ago A1 Jim mentioned buying magnetis sign material and making his own. He went to say they worked very well, so I tried it. At the time my tools were stored in the garage waiting for their new home. The sheets worked fine for me I bought the same material Jim reco’d, off e-bay IIRC) and if I have to do the storage thing again I’d do it over.
View lew's profile
lew
12932 posts in 4359 days
#3 posted 11-26-2018 08:31 PM
I’d think plastic drop cloths would be cheaper and just as efficient at keeping the surfaces protected.
View syenefarmer's profile
syenefarmer
546 posts in 3684 days
#4 posted 11-26-2018 09:26 PM
For covering your tools, I would just get some inexpensive moving blankets from HF or Northern Tool.
Vintagewood1960
#5 posted 11-26-2018 09:51 PM
Vintagewood1960
#6 posted 11-26-2018 09:56 PM
Some time ago A1 Jim mentioned buying magnetis sign material and making his own. He went to say they worked very well, so I tried it. At the time my tools were stored in the garage waiting for their new home. The sheets worked fine for me I bought the same material Jim reco d, off e-bay IIRC) and if I have to do the storage thing again I d do it over.
- Fred Hargis
Thanks for the reply Fred. I’m looking for a solution that I can use in an intermittent use hobbyists type shop.
View Andybb's profile
Andybb
2353 posts in 1207 days
#7 posted 11-26-2018 10:12 PM
- syenefarmer
They are the current free item with a purchase at HF. Buy 4 items separately and get 4 blankets.
Strange but I live in the Pacific NW and my shop is what my wife calls the garage and I’ve never had an issue with rust.
-- Andy - Seattle USA
Vintagewood1960
#8 posted 11-26-2018 10:46 PM
- syenefarmer
Strange but I live in the Pacific NW and my shop is what my wife calls the garage and I ve never had an issue with rust.
- Andybb
Vintagewood1960
#9 posted 11-26-2018 10:46 PM
I’m not at all concerned with covering the tools. I would think that not allowing the metal to breathe by having a fabric holding the moisture against it would exasperate the problem. Interested in creating a neutral environment where no moisture is allowed to get to the metal while I initially bring the cold tools up to the surrounding air temperature which is being heated much faster than the tools. In theory this should work so I’m looking for some confirmation this works.
View bilyo's profile
bilyo
959 posts in 1707 days
#10 posted 11-27-2018 01:17 AM
Set up a small fan to run during the time that condensation is a problem. For a 2 car garage, a 10-12 inch table top fan should work great. Even better If it oscillates . I cant explain the science behind it, but I know from experience that it works to keep condensation from occurring. The moving air will also help the metal tools reach air temp more quickly.
View kingpong's profile
kingpong
13 posts in 1418 days
#11 posted 11-27-2018 01:45 AM
A while back I got a roll of the stuff off Ebay and made covers for everything cast iron. Haven’t seen a bit of rust since I’ve started using them. On my jointer part of the bed isn’t covered because of the fence, and when I took the fence off to mess with it the part of the bed that was unprotected was covered in rust, while the protected part had none.
117905 posts in 4181 days
#12 posted 11-27-2018 01:49 AM
I have all of my tools covered with magnetic sheets I found that it has helped keep rust of my metal topped equipment, I have not seen any rust forming under my magnetic sheeting. It takes some getting use to remove these sheets when using the equipment that has covers on it, but all said and done I would do it again, the benefits outweigh the slight inconvenience of having to remove and replace the sheets before and after using any particular piece of equipment.
View CaptainKlutz's profile
CaptainKlutz
2216 posts in 2098 days
#13 posted 11-27-2018 04:31 PM
Yes, magnetic covers work.
Can also use: sheet of cardboard, tempered press board, plywood, or a blanket.
All you want is something covering the flat top to stop condensate forming on top, instead forming on the cover.
If you have large amount of water that runs off top and along edges of magnetic/cardboard sheet, the water will seep under the edge slightly. Once ignored my tools in Missouri garage for 6 months, and had some light rust staining around edges where top was flush with cover edge. Making the cover slightly larger than top, prevented the problem the next winter. Make sure cast iron tops are protected (wax-etc), and the top/cover are dry before covering for any long term storage.
+1 running a small fan to increase air flow helps to prevent overnight condensation. It reduces the temp differential between tools and ambient air which slows/eliminates formation of water droplets on tools.
My biggest condensation events always happened with garage door was opened to warm moist air, and shop tools were cold. Almost instant standing water on every horizontal metal surface in garage.
Best Luck.
