Forum topic by MrOrangeKitty | posted 11-23-2018 11:46 PM | 830 views | 0 times favorited | 3 replies | ![]() |
Topic tags/keywords: motors Hello, I have a Nova Comet II lathe. A label on the motor says “DC Motor” but also “115v 60hz”. Doesn’t 60hz imply AC current? The either the variable speed controller or the motor is burnt out. Teknatool (the maker of the Nova Comet II) does not carry parts for the Comet II anymore. Any ideas on where to look for parts? |
3 replies so far
#1 posted 11-23-2018 11:59 PM |
he AC from the wall is being converted to DC for the motor by a controller that also provides with the variable speed functionality. what is the experience you are seeing when you turn the lathe on? the motor should have 2 wires running to it. can you check with a volt meter if it is getting the needed voltage? that would help you figure out if it’s the controller or the motor (same goes for the controller inputs) -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#2 posted 11-24-2018 04:18 AM |
Double check the controller box. Mine filled up with dust causing it to overheat and shut off. -- Rick M, http://thewoodknack.blogspot.com/ |
#3 posted 11-24-2018 11:58 AM |
Teknatool (the maker of the Nova Comet II) does not carry parts for the Comet II anymore. Any ideas on where to look for parts? The Comet II is a current production lathe, no? Are you saying you can’t get parts from them for a currently made machine? |
Forum | Topics |
Woodworking Skill Share
13129 |
Woodturning
2775 |
Woodcarving
563 |
Scrollsawing
413 |
Joinery
1862 |
Finishing
6293 |
7846 |
32503 |
CNC Woodworking
324 |
Hand Tools
6418 |
Jigs & Fixtures
1781 |
Wood & Lumber
7236 |
1612 |
Focus on the Workspace
2609 |
1265 |
Woodworking Trade & Swap
5389 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9620 |
