Wood Filler (again)
Forum topic by JerryLH posted 11-23-2018 04:16 PM 928 views 0 times favorited 17 replies Add to Favorites Watch
View JerryLH's profile
JerryLH
196 posts in 1919 days
11-23-2018 04:16 PM
Topic tags/keywords: question mahogany finishing
Question please – (old question). Preferred wood filler? I have a mahogany dining table top I’ve glued up. I’ll likely use a satin or semi gloss poly as the eventual finish. I would like to end up with zero porosity. I’d greatly appreciate the benefit of your experience/knowledge. Regards
-- Develop your character -- for it becomes your destiny. Jerry - Mannford, Ok
17 replies so far
View Bill White's profile
Bill White
5242 posts in 4568 days
#1 posted 11-23-2018 04:29 PM
Look at vids on grain filling. Bunches out there, and the process is much better seen than read.
-- [email protected]
View Andybb's profile
Andybb
2376 posts in 1211 days
#2 posted 11-23-2018 07:05 PM
- Bill White
+1
Lots of options. For a large piece I would just try using a water based sanding sealer or a few coats of shellac. See how it works on the underside first.
Charles Neil - Grain filling mahogany. Chas is a member here.
-- Andy - Seattle USA
View DMiller's profile
DMiller
520 posts in 1080 days
#3 posted 11-23-2018 11:10 PM
Not sure whether or not you would like to draw attention to the area that needs filled or not, but my suggestion would be to get some coffee grounds and CA glue. Blend the coffee grounds as fine as possible, and put a small amount of glue on top. Seal the grounds in with glue and the sand the grounds flush. I have found this to work well in my projects; hope it helps!
Heres a picture of the idea. The black in between the inlay is the coffee grounds.
http://lumberjocks.com/assets/pictures/projects/1767753-438x.jpg
-- Dale Miller Modesto, CA "I can do all things through Christ, which strengtheneth me." Philippians 4:13. "Woodworking minus patience equals firewood."
JerryLH
#4 posted 11-23-2018 11:20 PM
Thanks for the feedback – not needing to fill defects – just wanting to fill the pores of the wood – not looking so much for how to – but rather some product names. Thanks again.
Andybb
#5 posted 11-24-2018 12:24 AM
- JerryLH
The Timbermate comes in different colors. It is a little more aggressive in that it can be mixed with water and actually fill the pours a little better. I used it on a table with mahogany veneer and it came out smooth as silk with 220 grit sandpaper. Should look nice with your oil based poly over it.
View robscastle's profile
robscastle
6675 posts in 2812 days
#6 posted 11-24-2018 07:10 AM
Timbermate in Alder…. OMG what will they think of next? ... and thats the shot for grain filling too!
-- Regards Rob
View MrUnix's profile
MrUnix
7597 posts in 2806 days
#7 posted 11-24-2018 07:18 AM
- JerryLH
For your first coat (or possibly more depending on how big the pores are), wipe it on and rub it around with wet/dry sandpaper. The sandpaper will create a slurry of poly/sawdust that will fill the pores. Once filled, finish as usual.
View Blindhog's profile
Blindhog
148 posts in 1656 days
#8 posted 11-24-2018 02:29 PM
Aqua Coat works very well on porous woods. 2-3 coats will provide a surface that you can coat with shellac and then whatever finish you choose.
Highly recommended.
-- Don't let perfection get in the way of plenty good enough
View Robert's profile
Robert
3602 posts in 2088 days
#9 posted 11-24-2018 02:37 PM
Aqua Coat or Old Masters work well.
You will have to decide on clear or not.
JerryLH
#10 posted 11-27-2018 02:51 AM
Thanks much for the feedback.
View BurlyBob's profile
BurlyBob
6912 posts in 2873 days
#11 posted 11-27-2018 03:30 AM
I remember some one here describing how they used Danish oil and sanding dust to create a slurry for a filler. As I recall they were sanding red oak and using the red oak sanding dust. Perhaps it could work with your project.
View JADobson's profile
JADobson
1448 posts in 2718 days
#12 posted 11-27-2018 02:43 PM
- BurlyBob
I’ve done that in walnut with danish oil and 220 grit sandpaper. Worked for me. I was working on a very small surface though (walnut pen presentation box in my projects).
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View bilyo's profile
bilyo
961 posts in 1710 days
#13 posted 11-27-2018 03:15 PM
You could use your final finish as a filler. This is an old time method that works very well, but requires lots of sanding. I used it on a mahogany table a few years ago and ended up with a glassy smooth finish. All you do is apply your finish to a properly prepared surface, let it dry, and then sand it back almost to the original surface. This will remove most of the finish, but leave finish in the pores. Add another coat and sand it back as before, Continue this process until all the pores are filled and then apply a couple of final coats. When you sand, use a flat sanding block. You can tell if the pores need more filling as they will show as tiny shinny spots. As you are sanding, if all the shiny spots are gone, then you are ready for the final coats. It is lots of work, but you will end up with a beautiful finish.
Your main concern when doing this is with any stain or dye you applied to the wood. In this case, you will want to apply at least two coats of finish before starting the sanding back. And, then be very careful that you don’t sand into the stain.
View CaptainKlutz's profile
CaptainKlutz
2251 posts in 2102 days
#14 posted 11-27-2018 03:28 PM
+1 search for grain fill, lots of videos out there.
For fine grain wood like mahogany when using simple poly finish, I like using BLO and sand paper to fill to grain. Watco natural Danish oil works as well, and will cure a little faster than BLO in cooler weather due oil/varnish blend. If you lightly scrape the surface cross grain to remove excess, can fill fine grain in one pass. Scrape to deep, and usually needs 2 passes to fill grain. The biggest drawback with this fill method, is time required to air cure BLO or Danish oil, before sanding flat and adding top coat.
For course/open grain wood like Walnut, or Oak, etc; I prefer to use commercial regular grain filler (like aqua coat for clear top coat, or Behlen’s water based if stain is used) as it is less work. Only need 1 maybe 2 applications to fill grain .vs. 3-4 passes with BLO. With these water based compounds, you can fill grain in few hours, and polyurethane top coat the next day if humidity is not too high. Here in dry desert SW, I can grain fill in morning, and apply first top coat in late afternoon. :)
YMMV
View oldnovice's profile
oldnovice
7517 posts in 3975 days
#15 posted 11-27-2018 06:08 PM
I have used Timbermate on a lot of projects and it has yet not let me down.
It works wonders on oak and other open grained woods I have used.
I have four of the different colors available and two containers of filler that I have colorized.
I filled some white oak with Timbermate that I had tinted to black and it looked a lot like zebra wood after sanding.
